Thats right , my R33 4 auto 4 door now totes an RB26dett :flamed:
Its been a long 12 months since the demise of the 1st 25 , with only a brief (4000 kms ) stint with a forgied 25 ( this is a long , costly & painfull story that I will leave to my Lawyers!) all of which lead me to , with a little help from that zoom article , putting an Rb26 into the 4 door.
Basicly , I was able to fit the 26 into the 25's hole by using the 25 engine mounts & just turning the drivers side 1 around 180 degrees.Then shorten the throttle cable , add a GTR radiator top hose & ta da!
I have retained to 25s engine loom so I can keep the Wolf ecu that alows me to run the auto , we just had to change the injector plugs to Bosch ones & change the function of the 25s VVT switch to now be the air temp sensor :)
Although , with the help of Wolf tech support , I am able to use the 26 Cam Angle sensor & change the way the map reads to Ref & Sync. (instead of the modified 25 cas , used for dual point sensing) which has made Cold starts much more reliable.
The 26 is out of an R33 GTR with 51 000ks on it , stock internals & injectors , & the only mods are GReddy adjustable cam gears.
The GTR turbs were rebuilt using T28 (SR20) zorst wheels & housings because they are Steel , & much bigger!
The auto remains stock ( bigger trans cooler coming) but using Redline Racing ATF
which has practically removed any "slip" on the now quite abrubt Gear changes :aroused:
The end result..........376.9rwhp with boost spikes to 20psi before settling to 18psi
& I am bloody happy with that!
The real test will be Drag combat on the 23rd of April so...fingers crossed no :Bang:
Thanks heaps To George & Sean from Adrenaline ( experience counts)
Bart for crazyimports.com
& Steve from Maytech
& here's the pics GTS26tt
https://www.sau.com.au/forums/topic/70472-gts26tt-d/
Well done Rep and good to see you using the local boys down there.
I know that Peter Blight has nothing but good things to say about George and his patience with getting it right.
Ohh and Maytech, who who get a lot more business if he realised most peoples working days are 8 till 5 , not 5 till 2 in the morning . lol :)
Dare I ask who the lawyer involves or is it probably someone I already know? :)
Cheers
ken
https://www.sau.com.au/forums/topic/70472-gts26tt-d/#findComment-1301410
nice man. Do u mind if i ask wat sort of figures this conversion cost?? I've been thinking about what i'd do if my engine cooked and just wanna know if its a viable option.
Congrats on the figures dude, bet you're stoked!!
I'm trying hard NOT to think about it dude ....
But I think 10k would cover it for a straight engine change ( including the engine that is)
It starts to add up when you go for Modded turbs , Split gate dumps Custom Intakes etc...trust me
Cheers
https://www.sau.com.au/forums/topic/70472-gts26tt-d/#findComment-1301516
Yeah nice work troy and good to see it all up and running nicely. It was a nice job Sean and george did on the blue rocket.
So the million dollar question what your guess on ET and MPH for DC.
Plus it will be good to have a couple of the buno boys at DC.
https://www.sau.com.au/forums/topic/70472-gts26tt-d/#findComment-1302621
Thanx Pete ,
As for ET & MPH , I'd settle for 12.5 @ 115..... as long as its better than my last run :) (except this is in street trim = No Nos)
I'm not sure quite how bad I want to beat up on it , but lets face it , by the end of the day I'll probably be Stalling it up against the handbrake!!!
https://www.sau.com.au/forums/topic/70472-gts26tt-d/#findComment-1302651
    • I haven't touched the turbos so might need to look at that 👍 Appreciated 🙏
    • If you haven't replaced the OEM turbos, replace them sooner than later. I have seen recent pictures of what OEM ceramic turbo failure can do in an RB26 and it will make a 10k AUD budget look like a joke. Single vs twins have been done to death on this forum. If your turbos haven't fallen apart you can probably send yours off to Hypergear for rebuild. The journal bearing option will have more turbo lag but it's a good bit cheaper. I would probably go for ball bearing CHRA but keep in mind ball bearing turbos are more particular about oil pressure/flow.
    • Clutch done also about a year ago got a DCS HD Single Plate. Basically done everything but touch the engine 🤣 But will definitely get a fuel pump and ECU, then start saving 🫡
    • Fuel pump and clutch and ecu that’ll get you to about 230 or so kw, after that the sky’s the limit and the budget blows out faster then you can blink
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
