u get raped..
and the cop waves his hands in the air as he rides your ass.. with a "Victoria is the best state in australia to drive"
:whip: :);)
You Vic's seem to get it harsh.
But, seriously I read that u guys get a fine, thats provided you havent broken any other infringements at the time. Just speculating, but could they also put you on a curfew for breaching the power limit rule?
Here in SA its much more lenient in regards to fines & demerit points (except with defects), & we dont have that power to weight limit rule for 'P' platers.
u get raped..
And if hes really lucky the cop will also be fisting steve bracks ass hole while he collects you $$ for driving an illegal car.
All in all it will be an experience to tell your grandkids about.
thats its im moving to qld  :D ,
how much the cheapest apartment there
much cheaper than VIC~~~~!!! 200 for a good 2 bed room town house with double garage in Brisbane...how does that sound~~!!???
i have to pay 290 for a 2 bed room town house with single garage in VIC......i need more money to stay in melbourne :cheers:
my worry wouldn't be what can happen if you get busted
If I was a P plater in that position I would be more worried about how the insurance companies would deal with any claim if you cause or are involved in a accident, you could find it used as an easy out for them on settling the claim.
a few hundred dollar fine is easier to deal with than having someone damage ur pride and joy and you having no comeback
*sigh* been there, done that :D
I don’t understand how insurance companies can take money from P-platers knowing fully that the driver is on their P’s and then not paying out when needed. That’s theft in broad daylight.
I got pulled over 2 weeks ago driving out of my street at 10am for a random check (random my arse). The cop was driving on the other side of the road then did a U-turn. They breath tested me and then, “Pop your hood.” He was then questioning if I can drive the can on my P’s. He wasn’t sure so that was the end of that.
Paradizzle, I’m from the west side. As for the insurance thing, I haven’t heard of it happening to anyone YET although when you sign up to an insurance company, they ask you for all your mods and if they are legal. So, if it’s not legal for P-platers to drive high powered vehicles, I would assume that they would not cover you. They find loop holes in everything.
    • I started with the above in my head too, and I might be reading / thinking about what they want wrong, which is why I complicated it a bit further. Purpose I'm seeing is for the corner indicator to be on with headlights, and then if the indicator turns on it can still flash. The relay part above I can see working as required, except in the case of headlight is on, and indicator is on. The change over relay you've wired in would get signal from the indicator, and as it flashes would give power to the globe from the indicator, but as it flashes off, power comes from the headlight, which would cause the indicator to be constantly on when headlight is on, even while indicator change over is flashing. That is unless we don't care if it flashes or not if the headlight is on? I guess that's an OP clarification.
    • HI, Ive got an r34 gtt sedan A/T. The instrument cluster went out and I replaced it with another A/T everything visually looks the same and all the gauges work now with the exception of the speedometer and odometer. The speedo will stay pinned at zero until I'm going about 55kmh and then it'll say Im going about 5kmh. my odometer seems to be tracking at about a 1/10 of what it should. If I go 1km it'll say I've only gone 0.01. Appreciate any and all help. Ive tried searching through the forums reddit and a local fb group. The only info I think I've found is that some cars didnt come equipped with TCS (mind is) and the clusters may be different between those? I've also installed a brand new VSS and no joy obviously. TIA.
    • what speedo healer did you use?
    • Certainly. It is probably broken under the wire style clamp. At least that one is easier to get at than the front one.   Sounds like it isn't a major leak, I'd start with backing off the the water feed and return banjos into the turbos half a turn then tightening properly. Hardlines can still crack over time, either in the tube (particularly when turbos are changed if the banjo is siezed in the the tube) or at the brazed joins between the lines and the banjo fittings. A coolant system pressure test will reveal all. BTW you'd be able to get a sump without exchange, it will just cost more as they will have to source another stock one for the next customer. If you want to address the sump a much better option is something like this https://www.hioctanedirect.com/hi-octane-racing-sump-extension-nissan-rb26 that you weld in locally (and add the oil return fittings at the same time)
    • Pretty sure you are thinking of the throwout bearing there (which you should change when you change your clutch), when they are worn they will get quieter if you put your foot on the clutch. An input shaft bearing is turning/noisy at all times.
