Hi There,
I recently put new brake pads in, EBC green stuff.
occasionally when coming to a stop (from high or low speeds) they screech really really loud, ear piercing.....
I have attached a pic of my brake pads and it just doesn't look right, should the shim only cover half the pad???
Thanks for your help
Cheers
Rob
https://www.sau.com.au/forums/topic/705-brake-pad-shims/
If I take everything appart, from the brake pad, there is:
-> The brake pad
-> 1st shim that attach's it self to the second shim (which clips onto the pad.
-> then the silver shim which only covers half the pad..
Is that right?
Cheers
https://www.sau.com.au/forums/topic/705-brake-pad-shims/#findComment-15928
Looks like mine, so should be ok... 3 suggestions ->
1. Shouldn't happen with new pads, but the two prongs (seen at the bottom of your picture) are wear indicators and make noise when the pad has worn down enough for them to contact the rotor. If that's the case, you need to bend them back a bit or get new pads.
2. Pull the pads/shims apart, wipe them clean of dust/grime/etc and spray on some "Anti Squeak" before re-assembly. The anti squeak needs to dry before assembly.
3. My pads/shims have ONE ONLY little clip each, that goes over the corner (top left or top right of the photo) of the whole thing. They have a little hole to match the existing holes that you see. Looks like these hold the 3 pieces of the pad from moving against each other, but are so small and flimsy that I doubt that's what they're for. As I can't see these, maybe you have to have them.
Hope this helps.
https://www.sau.com.au/forums/topic/705-brake-pad-shims/#findComment-16690
Thanks heaps for your reply MarkZ.
Unfortunately the thing is:
1) Pads are about 4 months old (heaps of pad leaft and prongs aren't touching as I bent them back)
2) I stuck all the shims together with this silicon orange goo stuff
3) Yeah I know the clips you are talking about (see attached pic) have them on as well.
Even after all that they still bloody squeek.....
Any other suggestions?
Thansk for your help
Rob
https://www.sau.com.au/forums/topic/705-brake-pad-shims/#findComment-16697
Rob
I pulled out mine to have a look and i have all of the parts listed above, when i put my new pads on they don't squeak even
without anti squeal stuff.
Have u tried machining your disc?
https://www.sau.com.au/forums/topic/705-brake-pad-shims/#findComment-17096
i just got mine from nissan...same as the s14 200sx brakes...made a BIG difference to braking...squeaky noise is gone and more pedal feel as well...check the pics out...dunno about the R33 part numbers though...could be the same...from your pics Robo it looks like we have similar sized pads...i might be wrong though
Part # 41080-40P27 HARDWARE KIT-FRONT D - about $80
http://members.optusnet.com.au/~ula32/Pics...cs/DVC00046.JPG
http://members.optusnet.com.au/~ula32/Pics/0.JPG
https://www.sau.com.au/forums/topic/705-brake-pad-shims/#findComment-23849
  • 1 month later...
Sorry ... just to revisit this old thread..... I installed my RaceBrakes pads today into the GTR rears and I COULD NOT fit the pads in with the shims as well....
So i totally removed the shims and installed just the pads... does anyone know if there is any problem with this?
Also I just started using the brakes and theres a fair bit of sqeual... is this cos they're new ??
https://www.sau.com.au/forums/topic/705-brake-pad-shims/#findComment-48287
  • 4 months later...
Guest too quick
Hi Robo,
just picked up my GTS-t and have the same squeeking problem... and the car has new brake pads and the discs are fine. I was told it because of the compound in the brake pads... I'm getting softer pads put in... they'll wear quicker but if they get rid ot the sound who cares... my dad worked for a car parts place and apparently many years ago now they changed the compound they use in brake pads these days so that the pads don't wear as quickly but I guess there's downsides to it!
Getting the car on the w/e so will test out the brakes and let you know!
Too quick
https://www.sau.com.au/forums/topic/705-brake-pad-shims/#findComment-111402
Okay i had the same drama (sound familiar to all the other replies) lol
I thought that it was the EBC green stuff on the front of my car.
but alas it was the EBC black stuff street kevlar its called on the right side rear that was making all the racket.
got it checked. disc machined/skimmed a second time and then refitted, tested, still squeaked. took em out checked everything in with the anti squeal. still squeaked.
took the pads out and put in Bendix standard rears or something poor and non kevlar and walla no squeak.
What the... i agree.
Apparently there isnt really enough weight in the rear of the R33 to make the rears work hard enuff or some crap like that. We apparently also share the same rears as a WRX. so there ya go. I have taken my car to Brakeswest in Myaree, they are nice guys and took time to check and test and test and test and test until the came up with some sort of solution.
who knows there is no noise now so I am happy, though i really wanted kevlar on the back. bugga
https://www.sau.com.au/forums/topic/705-brake-pad-shims/#findComment-112585
Your Brake shims have been cut.
Mine cover the whole brake pad both of them
The first shim isn't a solid shim as the middle is slotted.
The second shim is a full solid shim which has the pistion marks on it. They cover from top to bottom side to side of the brake pad.
https://www.sau.com.au/forums/topic/705-brake-pad-shims/#findComment-113150
    • I'm keen for this content to 😂
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
