do u have an aftermarket steering wheel on your car????
cause a have exactly the same thing happoen in my 33, and have been told that it is caused by having the wrong type of boss kit installed, i havent confirmed this yet.
also could be a little white plastic thing, that sits on the shaft thats your steering wheel bolts to, u have to take the wheel off to see it, these do break alot.
Cam.
https://www.sau.com.au/forums/topic/7053-hicas-light/#findComment-104153
Mangoboy - yeah it should be ok as long as its off when you are driving.
R33_cam - i had a stock wheel on mine, but it wasn't straight so it may have been taken off at some stage... but you are right, that can trigger HICAS probs.
https://www.sau.com.au/forums/topic/7053-hicas-light/#findComment-104174
PranK: yeah not being on straight prob would have caused it cause that little plastic thing that sits on the shaft, wouldn't have been contacting properly, it has 3 ridges that fit into steering wheel and it turns at the same time and goes thru some kind of sensors.
Cam.
https://www.sau.com.au/forums/topic/7053-hicas-light/#findComment-104181
There is a way to re-align the HICAS "lug" on the steering wheel. I'm not sure but it goes something like:
1) Remove steering wheel with front wheels dead straight.
2) Turn HICAS ring in hub fully anti-clockwise 3 or four times (or until it stops???).
3) Turn HICAS ring clockwise 3 times.
4) Replace steering wheel and do up nut to correct torque(don't ask me...).
5) Remove cable that hooks into the sensor on the steering rack (down near/below oil filter).
6) Drive car a round the block (I'd suggest both ways around the block).
7) Re-connect cable to steering rack.
8) Run HICAS diagnostic.
Can someone give this a go and let me know if it works (then I'll try it :uh-huh: )
https://www.sau.com.au/forums/topic/7053-hicas-light/#findComment-104252
I dont have an aftermarket wheel, but now that you mention it, last night we pulled off the wheel to take the dash apart, so we may have bumped or affected that plastic thing your talking about... The light comes on and off every now and then, but when you start the car it stays off, then after driving a bit comes on, then off, on etc..
How do you run the diagnostic?
https://www.sau.com.au/forums/topic/7053-hicas-light/#findComment-104309
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
