1st item:
Rockford fosgate punch 301x amp. used for less than a year but over a year old. my headunit was stolen i was keeping it for when i put another one in but i am used to no stereo and i won't be getting a headunit again for ages so i decided to sell this. It comes with 2 sets of rca's as well as power and earth cable and fuse. There is also a certificate from rockford fosgate stating the power.
price with wiring etc is 220.
2nd item:
GTR wing for r33 gtst. it is not a genuine wing fibreglass copy. Came with the car, no brake light. in the future i am might be looking at getting either a full flat boot or just a stealth wing. I'm not desparate to sell it but if i get $200 for it i'll let it go.
i am in frankston and go to uni at clayton, i would prefer meet up or pick up. I won't send the wing but i would consider sending the amp i guess. Pictures of rca's and cables will come later. Pictures were taken on my fone.
https://www.sau.com.au/forums/topic/70533-amp-and-wing/
Some specs on the amp to help:
* 40 W X 4 @ 4 Ohms RMS
* 72 W X 4 @ 2 Ohms RMS
* 150 W X 2 @ 4 Ohms Bridged RMS
* Total power 900 Watts Peak/Max
* Crossover : HP 80/120Hz 24dB per Octave - LP 80/120Hz 24dB per Octave
* Bass Control - 6 to 12 dB
* Low level RCA Signal input. Voltage - 250mV - 6 volts
* High Level - Plug (multi-pin). Voltage -.5 - 11 volts
* Line output
* 8 gauge Power Wire input
* Cast Heatsink
* Protection built-in
* Frequency response : 20 to 20k Hz +/- .5 dB
* Dimensions : 2.38 X 9.85 X 12.07 (inches)
https://www.sau.com.au/forums/topic/70533-amp-and-wing/#findComment-1305406
    • I'm interested if anyone agrees with what you've said, and can give a good reason. Temperature of powder coating should be below any temperature you'd use to alter the wheel structure.  Powder coat typically 200 to 250. Annealing if that's what people are claiming would be occuring, starts at 300, and depending on the alloy, can need even up at 400+.   That's the only part I can think of that could cause an issue that people are believing it's from the rim losing hardness and becoming too soft.
    • Negative probe should be on the cars chassis. Positive on the wire.   Start as said above by unplugging everything (unplug the lights, and switches. Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch. If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.   Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.
    • Anyone know if it's a problem to powder coat forged alloy wheel centers (Rays/Volk GT-C). some say it's bad and can damage the alloy, some say it's not a problem.
    • Hey guys, I'm reviving an old post but I'm finally getting around to working on this now. I removed the battery to get a better look at the wires and i traced the wires from the headlight to the fuse box in the engine bay, but the wiring looks fine? The wiring for the R/H headlight is 3 wires and then is bundled up with the large diameter wire that goes underneath the fuse box. I didn't take it apart yet. I know you said that its a short circuit somewhere between the fuse box and the headlight. But could it be the headlight switch on the dash? Also, i pulled out my multi-meter and set it on the Ohms, but i'm not sure where to put the negative probe and the positive probe.
    • I have a 2 lt in Sydney. It was fitted on a R33 GTR, not used for several years . If you are interested email me on: [email protected] I'm not on this forum much .
