1st item:
Rockford fosgate punch 301x amp. used for less than a year but over a year old. my headunit was stolen i was keeping it for when i put another one in but i am used to no stereo and i won't be getting a headunit again for ages so i decided to sell this. It comes with 2 sets of rca's as well as power and earth cable and fuse. There is also a certificate from rockford fosgate stating the power.
price with wiring etc is 220.
2nd item:
GTR wing for r33 gtst. it is not a genuine wing fibreglass copy. Came with the car, no brake light. in the future i am might be looking at getting either a full flat boot or just a stealth wing. I'm not desparate to sell it but if i get $200 for it i'll let it go.
i am in frankston and go to uni at clayton, i would prefer meet up or pick up. I won't send the wing but i would consider sending the amp i guess. Pictures of rca's and cables will come later. Pictures were taken on my fone.
https://www.sau.com.au/forums/topic/70533-amp-and-wing/
Some specs on the amp to help:
* 40 W X 4 @ 4 Ohms RMS
* 72 W X 4 @ 2 Ohms RMS
* 150 W X 2 @ 4 Ohms Bridged RMS
* Total power 900 Watts Peak/Max
* Crossover : HP 80/120Hz 24dB per Octave - LP 80/120Hz 24dB per Octave
* Bass Control - 6 to 12 dB
* Low level RCA Signal input. Voltage - 250mV - 6 volts
* High Level - Plug (multi-pin). Voltage -.5 - 11 volts
* Line output
* 8 gauge Power Wire input
* Cast Heatsink
* Protection built-in
* Frequency response : 20 to 20k Hz +/- .5 dB
* Dimensions : 2.38 X 9.85 X 12.07 (inches)
https://www.sau.com.au/forums/topic/70533-amp-and-wing/#findComment-1305406
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
