$100 to fill a 10lb bottle. How many runs you get out of it depends on the size shot you use. Longevity? How's 18 months on the bottle and near 80 passes @ WSID and 50 laps of E.C.Raceway sound with NO DRAMAS!?!?!?!?
Don't talk about longevity... hahahaha....
Adrian
  • Replies 51
Sorry make that "80+++ passes at WSID, 50+++ laps at ECR all on the bottle as well as a few hours on the dyno over time AND the regular racing and street driving off the bottle.
Driven this cars arse off for near 3 years with no ill effects.
Ssshhhh....!!!!
Adrian
I aggree but the long term longivity of your motor seems that it is going to be short lived. It seems by spending money is to save money build it once and do it right.
Correct me if im wrong 2rismo but your car is making approx 270rwkw on std turbo with nos?
With a proper tune that's hardly damaging the engine (or no worse than whacking an aftermarket turbo on and getting a similar power level...). Not to mention it would have been cheaper and easier to tune no doubt.
This is an example of ongoing costs what is it around $100 to refill
GTSTBOY
Every motor has a power limit and an rpm limit.
The amount of nitrous suggested by 2rismo + his existing base power without gas is arguably within the power limit of the RB25det engine components. Therefore the longevity is not in question if the comarison is made bewteen a turbo upgrade of the same total power. The rpms required by the nitrous shot are typically lower and the intake charge temps are lower giving another advantage to a nitrous system in terms of wear.
The ongoing costs are hardly an issue for someone who wants to race a car.As they say.." if you want to save your pennys go and buy yourself a moped". Tyres and fuel alone cost enough to turn some people off. Not to mention the clutches, gearboxes and diffs.
I actually believe 2rismo may crack a 10.99 second pass with the larger shot he is now runing (although he doubted me last time I said this) since the torque difference over his last setup should be massive. Of course that my call not his.
10lbs of gas lasts longer than you think . When you actually own a car with a kit on it you keep feeling it's such great value for money every time you flick the switch :) Just ask anyone who has had a well setup kit on thier car and I'm sure they will tell you the same.
This thread is all about learning. So I hope we can add some info to your as yet incomplete understanding of nitrous use for performance.
I did doubt you, didn't i ?? ;):P;)
I run 1 heat range colder (an 8) with my usual 0.8mm plug gap and they work great.
Adrian
It sounds as if you are going to big on a standard motor why don't you just spend some more money on a proper build instead of NOS
GTSTBOY ;)
Re this post;
Building a motor wouldn't give me any more power than I have now without the gas. As I'm not hurting the car now, why 'build it'?
Adrian
The car makes about 200rwkw without the gas as the above-mentioned boost levels and about 260rwkw with the gas.
Two different DD dynos recorded 258.8kw and 259.1kw respectively in Shootout Mode. I expect more like 300kw with the new jetting but lots more torque. Can't remember the tractive effort figures off the top of my head though.... Does 1420ft sound right?
Adrian
For the 60 rwkw increase (as in 2rismo's case) how long does a 10lb bottle last? Number of passes or engine time, whatever?
Around here the going rate for 10lb bottle refill is $55 inc GST, what's it cost over there?
:rofl:
I usually get about 14 passes before the performance suffers. This is due primarily because the bottle pressure drops significantly when it runs low and until recently, I didn't have the recommended bottle warmer fitted. These warmers maintain a constant temperature (and therefore pressure) using a thermostat and are a very simple electrical prospect.
16-18 passes down the quarter mile from full to empty on my bottle seems about right. When it's only (mainly) used in quarter mile applications it's a great value for money prospect involving little or no compromise in how the car drives daily.
Adrian
Some one asked about plugs?
Usually you run a colder plug and go for one with a decent size grounding strap, the NGK copper plugs all seem to be ok. That means no iridium/platinum or any self cleaning style plugs. The BCP 7's I found to be quite ok.
Adrian
Thanks Adrian, what's a 10lb refill cost?
    • Thanks Murray, appreciate the advice, a few things to think about now 😀
    • After my million questions, I'll throw in my 2c now.  If I was in your shoes, I would buy the best/most modern ECU available. A Nexus S3 would fit the bill. It is highly likely that this ECU will last the life of the car, regardless of whatever ECU manufacturers develop in the future. Modern ECU's are amazing and will still be amazing in 10 or 20 years time. If you can get e85 relatively close to where you live, I would buy a flex sensor and size the injectors to run e85. I'd go a Walbro 525 fuel pump with relay wiring kit.  Turbo wise, I'd hit up HyperGear and get a pair of the biggest bolt on turbos.  Now for the safety side of things, I'd have the tuner setup the tune to be very soft/safe on 98. Then on the flex tune, a lot of the timing can be put back in on the top end (I'd run full boost on both tunes, but manipulate the power with the timing). This also has the benefit of hopefully delaying the, "bored now, need more boost" that comes with owning a modified turbo car. If you spend most of your time on the 98 tune, the few times your on e85 will hopefully stay special/fun.  The bad news. As your paying for labour and tuning, I don't think this will happen with $10,000. This might be the motivation to learn to do it yourself though, that way instead you'll have the built car and change from the $10,000
    • Cheers Duncan, on club reg and very much a weekender, don't drive it all that hard and don't intend to go overboard at any point in the future too. In my 40's and quite mature driver, just want that little bit more from it 😉 Sounds like, after ensuring everything is in good condition, ECU, Injectors, Fuel Pump and a set of turbos is likely to be my path forward.
    • 15 years is not too long to hold onto something like that, right?
    • Hey man,   By any chance you still have sunroof for sale ?   Thanks
