Hi Adrian
Are there any ways to control nitrous delivery?
From what I understand when its activated the jet flows 100% straight up.
Is there ways of adjustment, or additional products that can be added so that when the nitrous is activated it starts off flowing say 15%, then 40% and then 100% flow over say 2 seconds?
Or a way to control its delivery flow cross referenced against rpm? Like 3krpm 25%,4k 50%, 5k 80% etc ?
  • Replies 51
Hi Adrian
Time based and electronic progressive nitrous controllers have existed for a very long time and operate by pulsing the solenoids on and off for programmable periods.
I'm shopping for one right now actually. Some of the electronic ones do everything you've suggested and more.
Adrian
If I was to setup my motor for NOS (RB30DET- wiseco forgies etc...). What clearances and other parts of the engine should be changed internally to suit ?
Nothing needs to be done any differently with nitrous use compared to any other increased hp application. Some things to bare in mind are very common changes like spark plug gap and temperature. Expect inlet temps to be greatly decreased and exhaust gas temps to be noticably increased.
2rismo which kit do you use on your car ?
And where is a good place to purchase the required gear from ?
I use an NOS single fogger (one nozzle) wet system (fuel + nitrous oxide). The best guy to speak to (at least, the guy I get just about everything I buy from) is Steve @ Steve's Speed Shop on 02 42577333 or 02 425SPEED. In fact, I now get so many enquiries about my setup, you are more than welcome to call Steve and ask how much, "..a kit just like 2RISMO's is?"
:D
Adrian
haha cheers mate :)
    • Thanks Murray, appreciate the advice, a few things to think about now 😀
    • After my million questions, I'll throw in my 2c now.  If I was in your shoes, I would buy the best/most modern ECU available. A Nexus S3 would fit the bill. It is highly likely that this ECU will last the life of the car, regardless of whatever ECU manufacturers develop in the future. Modern ECU's are amazing and will still be amazing in 10 or 20 years time. If you can get e85 relatively close to where you live, I would buy a flex sensor and size the injectors to run e85. I'd go a Walbro 525 fuel pump with relay wiring kit.  Turbo wise, I'd hit up HyperGear and get a pair of the biggest bolt on turbos.  Now for the safety side of things, I'd have the tuner setup the tune to be very soft/safe on 98. Then on the flex tune, a lot of the timing can be put back in on the top end (I'd run full boost on both tunes, but manipulate the power with the timing). This also has the benefit of hopefully delaying the, "bored now, need more boost" that comes with owning a modified turbo car. If you spend most of your time on the 98 tune, the few times your on e85 will hopefully stay special/fun.  The bad news. As your paying for labour and tuning, I don't think this will happen with $10,000. This might be the motivation to learn to do it yourself though, that way instead you'll have the built car and change from the $10,000
    • Cheers Duncan, on club reg and very much a weekender, don't drive it all that hard and don't intend to go overboard at any point in the future too. In my 40's and quite mature driver, just want that little bit more from it 😉 Sounds like, after ensuring everything is in good condition, ECU, Injectors, Fuel Pump and a set of turbos is likely to be my path forward.
    • 15 years is not too long to hold onto something like that, right?
    • Hey man,   By any chance you still have sunroof for sale ?   Thanks
