Hey Guys
I have a 400r front bar (to suit S1 GTST) that has just come out of a mould and will be ready on saturday 30/4. I am selling it for $425 it is unpainted and clear indicators can be supplied for $150 a pair. I can post a pic if needed but im sure you all know what a 400r bar looks like.
Lee
Edit - The pics are now posted. These are the best i could get as the bar isnt finished yet.
Dont hesitiate to call me if you have any Q's 0401 531 623
https://www.sau.com.au/forums/topic/70546-400r-front-bar/
Yes there is, its here http://www.skylinesaustralia.com/forums/sh...ead.php?t=70196
Im not selling this one now because that way it will give people a chance to save and come over and inspect the front bar to make sure that are happy with the final product.
For those that cant wait, i should be able to get one or two bars through until the large order is out of the way.
https://www.sau.com.au/forums/topic/70546-400r-front-bar/#findComment-1316608
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
