rear strut bars on R33 GTST's mount in the boot, not actually "on top" of the struts.
If you open the boot and remove the the cover that is hiding the battery etc. and look at the back of the strut towers you will see two threaded "bolts" on each strut tower. Mine have little PVC hoods on them so yours might as well. Pull the hoods/covers off the bolts and this is where the strut bar attaches.
I checked my boot first and the tower bolts are not accessed from there.
You have to go through the back seat and they are located under the parcel tray.
Its definitely them, they have the rubber boot covering them and it looks like you'd have to hack away at some steel to fit the bar??
Mine is a '93 aswell :confused:
I did that already and they can only be accessed through the back seat.
From the bootside you can see the outside of the tower and their is a steal plate from the strut tower to the parcel tray in front of where the tower bolts are located. so they cannot be accessed from the boot.
I have circled the 2 bolts (with boots on) in the picture...same deal on the other side.
If your strut bar doesn't fit up to these points then I suspect you have the wrong type of bar (possibly a GTR one).
aaah - those bolts :Oops:
so installing on those bolts will help chasis rigidity then as in the front? Did nissan include those bolts for this purpose? Shame they didnt include any nuts aswell!
I was thinking that you had to install them on the top of the strut towers like on the front. And of course the only way to access the rear tower bolts is from behind the backseat.
Thanks for your help - much appreciated :)
According to SydneyKid the rear strut bars aren't as important as the front ones, but they must add some extra rigidity.
The rear strut bars were a factory option I believe so, yes, Nissan intended the bolts for this purpose.
If you can't find a suitable nut at your local hardware try somewhere like Coventry fasteners.
Thanks for your help - much appreciated  :cheers:
No worries :D
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
