I'm thinking of getting HKS adjustable cam gears, but I have a few questions. What's the best price I can get them for? (Sydney) Perfect Run have them for $255 each which seems like a reasonable price.
How hard are they to install/adjust yourself? How do you actually adjust them? How will they affect my power and running of the engine?
https://www.sau.com.au/forums/topic/7056-adjustable-cam-gears/
  • Replies 74
Jimx,
I'm getting some adjustable cam gears for my 'line too. I was going to get HKS but have been deterred buy a few people who have said the HKS can be unreliable and break too easy due to being made from aluminium.. Apparently they have a habit of wearing the teeth out and the timing slipping. These guys do have very big hp cars so maybe for the average joe like us it would be ok, but I'm going for a set of JUN steel cams sprockets which are only about $60 more than HKS for the set....
Just my 2c...
Brett
Nengun has HKS gear for $185 each.
http://www.nengun.siteblast.com/courses.as...id=57739&page=1
But I've heard on SDU that they aren't too reliable. With only 3 bolts holding it in place, some people have found the gear to slip under load and mess up timing.
Sub-zero have Toda gears for $165 each. They use 5 bolts to hold the gear in place, so it seems like a better bet. I haven't used either product though.
http://www.sub-zero.com.au/engine.htm
I think someone mentioned in another thread that it's about a 10kw increase and the turbo kicks in about 200rpm earlier, both of which are good enough reasons to get them IMO.
What I mainly want to know though is how hard would it be to do myself? Is it simply a case of removing the timing belt and associated covers etc then bolting on the new gears, then replacing everything? How do you set them up exactly? (like which holes go where)
dun u think better leave it to the mechanic, coz if u mess up ur timing, ur valve will hit ur cylinder head n bang goes ur engine...
even if you manage to install em urself, as long as you noted the correct position of the cam before changing it, u still need to tune the timing on dyno anyway....
I've got one on my exhaust cam shaft. If you have a look at my dyno sheet, you'll see it actually causes a dip in the power right after the NVCS (I think that's what it is called) kicks in. I'm not sure how much more power it gave me (if any) - it wouldn't have been much though maybe a few rwkw's.
I'm not sure what effect it would have on the intake camshaft, but you can buy them. I can't see it screwing up anything, but don't blame me if it does.
Hi Guys,
We have been discussing similar questions on a camshaft thread. The cheapest price for HKS gears is from nengun at $185 per gear plus shipping. If you can organise a group buy he can fit 5 sets for one shipping cost, bring the price to about $200 each landed. I've not heard of anyone using the Toda gears, but I would imagine they are just as good as HKS, just not a flashy looking.
The best way to use the gear is as a set, inlet and exhaust. The best results for power is if the exhuast is retarded 4deg. from the inlet cam. There is no point getting a mechanic to fit them unless your planning on having them just for looks, you will need the car to be on a dyno to get real results. It's not something you should try yourself unless your experienced with timing and have a good timing light.
If you still have factory cams then 10-15kW is probably all the power difference you will get, but you can get improved torque and turbo response with them. If you have programmable management then the dip around the NVCS shouldn't occur with a competant tuner.
One of the guys on our thread will be getting his car tuned on Monday and posting the results, so stay tuned.
See'ya:burnout:
If you where going to put one on the intlet would you disable the variable cam timing? I am just thinking if you advance with a cam gear you would get a summed advance with the variable timing, and it would negate the retard from the variable timing. I have only heard of exhaust cam gears on R33s. Anxiously awaiting your results if you give it a go.
Edit: Should have read the cam post then I would know GT N1K is trying it tomorrow :D
For RB25DET's, its not possible to fit a cam gear onto intake shaft without remving VCT timing sensors and possibily swapping the intake cam shaft for a non-VCT item. So people with stock cams only need one adj cam gear, for exhaust cam.
b2barker and Gradenko,
Yes thats right, adding the inlet cam gear will negate the effect of the NVCS, which is what most of us are aiming for, but stock cams are fine I believe, can anyone confirm?. Inlet and exhaust cam gears will provide the best results, but that is not to say that exhaust gear alone wont help.
Yes GT N1K is giving it a go tommorow, we eagerly await his results. There is also discussion on the reliability of the HKS gears and other gear manufacturers. It would be good if you guys have anything to contribute on these issues.
See'ya:burnout:
Hi Guys,
YO880,
A set of adjustable cams gears will work great with a Power FC, they will add 10-15kW on factroy cams, with aftermarket cams with larger separation the difference will be huge. Do note that it will remove the NVCS, variable cam timing.
MIC33R,
With an SAFC there is not much that you can do about the dip, so they didn't stuff up. You will see some minor improvement with the exhaust gear, and unless you get aftermarket management, probably not worth doing the inlet cam gear.
400HP,
Those prices sound about right, but if you organise a group buy then the freight can be split. Check out sub-zero though, they have HKS and Toda at very good prices. I haven't had anyone actually say that they have had first hand experience with the HKS gear breaking but there are plenty of rumors.
Everyone,
I am organising a group buy in Perth (5 sets), as even if I only get them for myself we have enough cars to put them in. I should find out on Moday what deal Sub-zero can do and then let you all know. It's too difficult to worry about shipping them around the different states, so I'd encourage you to do a group buy with some of your mates.
See'ya
:burnout:
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
    • @KinkstaahKrinkle paint the "silver" alloy, not the red filter frame Engine bay heat won't be a issue worth worrying about as the silver alloy blocks it off on 3 sides, as for the top, the bonnet seals most of it and the big OEM CAI intake snorkel is still fitted in its original position  I will head into Clark's Rubber when I have some time to grab some pinch weld to tidy up the alloy after I paint it As for performance, I honestly wasn't expecting any, the only reason I got it is because the intake noise sounds cool to my old ears when I'm feeding it the beans Sometimes it's the silly things you do in in life that gives the most fun, and I do love anything that makes cool car noises In other news: I survived 4 nights at sea with Jackie not throwing me over board, holidays are continuing now as we are currently chilling at the Beachcomber in Toukley, after taking the coast roads from Sydney in the MX5, top down all the way, Toukley is where I spent a good deal of my youth holidaying during the summer months, there's lots of reminiscing going on,  and lots of beaches and old houses to visit Next on the list is to head to Batemans Bay for a few days, but we will take the Commodore out to stretch its legs, then Commodore hasn't really moved for months
    • There’s probably people who’d like to do it and then when it comes to putting their hands in their pockets they’ll all disappear into the shadows
    • interesting....sounds like the later trans has software differences (or AM vs JDM). If I wasn't going down the tuning route it would be worth looking into retrofitting a new computer to the old box.
