anyone in NSW wanna organise one? hopefully we can leverage off GTS-T Vspec's deal with sub zero? i will need to get a set fairly soon though.. i think the cam gears are the same for RB25DET and RB26DETT arn't they?
  • Replies 74
Hi Guys,
I got a response back from Sub-zero about the HKS vs. Toda.
the Toda gears are alot better than hks because of the aluminium they are made
of..
Toda is 7000 series alloy
HKS is 6000 series alloy
Sub-zero
I am not happy with the price they offered, so I'll continue to screw the price down. Currently nengun is cheaper, and I've ask him to see if he can get other types of cam gears.
Anyone else have a possible source?
See'ya:burnout:
Theres also STR Power, an american based company who have adjustable gears available for the RB26 on request from Motorex. Very well made.
http://strpower.com/strcamgearintro.htm
I've send them an email asking for single pricing and 5+ set pricing to Australia. It probably won't be good news though, considering the value of the aussie peso.
Originally posted by GTS-t VSPEC
quote:the Toda gears are alot better than hks because of the aluminium they are made
of..
HKS is 6000 series alloy Sub-zero
Ask them to explain exactly what this means....believe me, it's not a case of bigger numbers being 'better'.
I was about to order HKS and after hearing stories from a friend I've decided to give the HKS a miss. I am now going to probably get the Tomei Cam gears. Tomei make two types - 1) A steel wheel with steel teeth and 2) an alluiminium one.
Someone has told me that the alluminium one has steel teeth still. Does anyone know?
Also how much difference would you expect the weight of the gears to make?
I use HKS cam gears and my rb20det puts out 210rwkw and my friends rb20det s13 silvia also has them and his car makes 250rwkw. Neither of us have had any problems with them breaking or changing the settings.
They need to be set up on a dyno. We spend nearly 8 hours on the dyno to get them just right.
Cam
Hey Guys,
Good comments from all of you. I don't know how much of a difference the 6000->7000 grade aluminum makes, but they recommend the Toda gears and they sell both.
Yes you do see HKS gears on big horsepower cars, I never said they break, but there do appear to be alot of rumors as to there reliability.
Dialling in the cam gear will take a while on the dyno, there is alot of adjustment between the overlap between the inlet and exhaust cams, each providing a slightly different power curve.
400HP, How much for the Tomei ones?
Gradenko, The more prices the merrier, although after looking at the price of the Jun gear I'll give them a miss.
See'ya
:burnout:
Brody
I have had heaps of interest but it seems that people prefer to pay 17k for a car and then mod it ???? Perhaps these people don't realise how much it REALLY costs to mod a car.
I have one guy that seems super keen but is unable to get up to see my car so I hope he sorts himself out soon so I can sell it.
Cam
  • 1 month later...
My mechanic has offered me a set of adjustable cam gears for my s2 r33.
Should I get them now that I have:
pod filter, FMIC, turbo back exhaust, high flow cat, high flowed turbo, and a profec B (on its way from nengun).
My mechanic also mentioned that to increase boost above 1bar (which he recommends me running after its been on the dyno to see if everything is ok) I would need to get a aftermarket fuel pump and then if needed, injectors.
Finaly, what sort of price should I pay my mechanic to install the cam gears if i end up purchasing them?
BTW, once i get whatever is needed to get me 13sec 1/4 miles i'll get a powerFC.
Mark
If anyone in VICTORIA would like to be in a group buy, i would like to be in it. PM me and let me know, please.
I am assuming that the WOLF 3D V4 ems could take full advantage of this, and can eliminate the NVCS.
This buy would need to happen soon though, as my WOLF is being upgraded and retuned next week (to eliminate some minor bugs)
  • 1 month later...
I know this doesn't really fit in with the group buy tack that this thread is taking, but I have a mate that owns a pretty kick ass machine shop and he said that he reckons he can make cam gears no worries if he has a design to copy from.
I told him if he could do it cheap enough, he'd sell bucket-loads of em. The prototype(s) would be fitted to my car and dyno tuned with before and after results recorded.
** All I need is a gear to copy from in the first place **
Anyone?
Cheers,
Adrian.
    • Yeah, the latter. No diff should have a centre replaced without checking clearances because its unlikely to be the same as whatever came out. Not that that stops most people just checking a new centre in
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
