anyone in NSW wanna organise one? hopefully we can leverage off GTS-T Vspec's deal with sub zero? i will need to get a set fairly soon though.. i think the cam gears are the same for RB25DET and RB26DETT arn't they?
  • Replies 74
Hi Guys,
I got a response back from Sub-zero about the HKS vs. Toda.
the Toda gears are alot better than hks because of the aluminium they are made
of..
Toda is 7000 series alloy
HKS is 6000 series alloy
Sub-zero
I am not happy with the price they offered, so I'll continue to screw the price down. Currently nengun is cheaper, and I've ask him to see if he can get other types of cam gears.
Anyone else have a possible source?
See'ya:burnout:
Theres also STR Power, an american based company who have adjustable gears available for the RB26 on request from Motorex. Very well made.
http://strpower.com/strcamgearintro.htm
I've send them an email asking for single pricing and 5+ set pricing to Australia. It probably won't be good news though, considering the value of the aussie peso.
Originally posted by GTS-t VSPEC
quote:the Toda gears are alot better than hks because of the aluminium they are made
of..
HKS is 6000 series alloy Sub-zero
Ask them to explain exactly what this means....believe me, it's not a case of bigger numbers being 'better'.
I was about to order HKS and after hearing stories from a friend I've decided to give the HKS a miss. I am now going to probably get the Tomei Cam gears. Tomei make two types - 1) A steel wheel with steel teeth and 2) an alluiminium one.
Someone has told me that the alluminium one has steel teeth still. Does anyone know?
Also how much difference would you expect the weight of the gears to make?
I use HKS cam gears and my rb20det puts out 210rwkw and my friends rb20det s13 silvia also has them and his car makes 250rwkw. Neither of us have had any problems with them breaking or changing the settings.
They need to be set up on a dyno. We spend nearly 8 hours on the dyno to get them just right.
Cam
Hey Guys,
Good comments from all of you. I don't know how much of a difference the 6000->7000 grade aluminum makes, but they recommend the Toda gears and they sell both.
Yes you do see HKS gears on big horsepower cars, I never said they break, but there do appear to be alot of rumors as to there reliability.
Dialling in the cam gear will take a while on the dyno, there is alot of adjustment between the overlap between the inlet and exhaust cams, each providing a slightly different power curve.
400HP, How much for the Tomei ones?
Gradenko, The more prices the merrier, although after looking at the price of the Jun gear I'll give them a miss.
See'ya
:burnout:
Brody
I have had heaps of interest but it seems that people prefer to pay 17k for a car and then mod it ???? Perhaps these people don't realise how much it REALLY costs to mod a car.
I have one guy that seems super keen but is unable to get up to see my car so I hope he sorts himself out soon so I can sell it.
Cam
  • 1 month later...
My mechanic has offered me a set of adjustable cam gears for my s2 r33.
Should I get them now that I have:
pod filter, FMIC, turbo back exhaust, high flow cat, high flowed turbo, and a profec B (on its way from nengun).
My mechanic also mentioned that to increase boost above 1bar (which he recommends me running after its been on the dyno to see if everything is ok) I would need to get a aftermarket fuel pump and then if needed, injectors.
Finaly, what sort of price should I pay my mechanic to install the cam gears if i end up purchasing them?
BTW, once i get whatever is needed to get me 13sec 1/4 miles i'll get a powerFC.
Mark
If anyone in VICTORIA would like to be in a group buy, i would like to be in it. PM me and let me know, please.
I am assuming that the WOLF 3D V4 ems could take full advantage of this, and can eliminate the NVCS.
This buy would need to happen soon though, as my WOLF is being upgraded and retuned next week (to eliminate some minor bugs)
  • 1 month later...
I know this doesn't really fit in with the group buy tack that this thread is taking, but I have a mate that owns a pretty kick ass machine shop and he said that he reckons he can make cam gears no worries if he has a design to copy from.
I told him if he could do it cheap enough, he'd sell bucket-loads of em. The prototype(s) would be fitted to my car and dyno tuned with before and after results recorded.
** All I need is a gear to copy from in the first place **
Anyone?
Cheers,
Adrian.
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
