  • Replies 125
Hmm sounds like fun..i love dyno days!!!!
Might try & come along & see if i can better my 372rwhp i got @ Hyperzone yesterday
Will see if Sheree (61RLY) wants 2 come along with me & represent us Chic Torque girls???
Anita
hey Erin
how do i join SAU QLD club???
this will be my first dyno day...any tips (like is it wise to have fresh tyres..?)
i am 99% sure ill attend (pending reply to my questions)
Different people have different ways of preparing for a dyno, but I normally just turn up. I make sure my car has not long ago been serviced and is in good running order.
In regards to tyres, you don't need to have brand new tyres, but the tyres can't be bald either. They need to have some meat on the so they can grip the dyno.
Hi Have you guys thought about asking Mercury to invite a couple of other clubs?
Mercury have some close relationships with a few clubs, and I'm sure you could get closer to 30 if you invited some others directly.
ie rexnet, redline, ozhonda, clubvr4 etc etc
Its a bit too far for me, but I might be up for it.
I'll confirm a spot with you guys if you like in a week or so... ?
thanks
Michael
:P
As Will just mentioned, it doesn't matter how much power your cars got, it's just a fun day out and you get to see how much power your car makes.
But when/if the Hardcore/other high HP cars start turning up, they will try and make it a dyno comp, but it's not in the least a comp, it's just a fun social gathering with a hint of cars thrown in :D
yer ill pm you. nar it will be gud cause i dont really know any other ppl with skylines yet
i been tuned on a dyno but never been to a dyno day. well i aint had me car for long either lol.
chance for me to meet some other local skyliners
be there...
Ok.. Im coming but wont be running...
As of about 4 hours ago i have added another engine to the junk pile. Cracked the head (very large crack too) cold air said hello to very hot piston. Very hot piston said i want out of here. Oil and fuel and water everywhere and small fire finished off the rest. Ive had enough with this old rb20 im going to junk it as there is nothing good on it and stick to my r33 from now on. Thats right people, im quiting cold the sphincter of the universe the GTS-X is going. Cry :rofl:
    • Don't "upload" the pictures. Just copy the picture direct from somewhere (I usually am pasting screenshots or something else that I have on the clipboard as an image, not as a file" and just paste it direct into the post editor. Just like you were pasting it into a Word doc or something. You can't damage something if you lift it where you are supposed to. If you look carefully at the correct jacking points, you will see that they are reinforced right there. And nowhere else. That is where the "foot" of the factory jack is supposed to sit. That's why you need rubber pads with slots. 10mm might not be deep enough. Note also that the slots are not required if the pinchweld has already been slammed flat. You could just lift it at the correct spot with a flat pad, because the damage is already done. No point in making worse though, if it is recoverable. IF. Yes, that's called a chassis rail. You can lift carefully on these, if you spread the load. A decent block of wood is good. But keep in mind what I said before. Any time you start doing this sort of thing, you are off the normal path and into "be bloody careful", because it is obviously not stable. Dumb. The refinforcement is already there. See above.
    • yeah looks like they've been lifted there previously but with solid not slitted rubber blocks. I'd just bend them back (combination of vice grips or hammer with some sort of drift, then hit the area with underbody protection paint. As for the siderails, I'd call those chassis rails and that is exactly what I meant about being careful with the balance point. You can probably lift off them at the point where the 2 pieces overlap, but you need to be careful with the forward balance of the car if you do when the engine is in....sills are a better choice. I guess you could weld some reinforcement in the sill area near the jacking points but it shouldn't be necessary if you use blocks with a slit. If you do want to reinforce it I'd use square section equal or taller than the seam and then just use flat rubber blocks for lifting
    • driver side sidemember and jacking point (looks the worst by far) driver side rear jack point passenger side sidemember and jack point passenger side rear jack point   Ignore my mug on the last photo. Turns out I was just too stupid to properly use the forum's attachment feature previously
    • Fk me, I guess next time I will try to use the onsite attachments feature. I find it hard to work with so far though because I can't move the images to where I want them to be. I will try to make a separate post with just images. As for lifting. The work I need to do for now involves the exhaust and engine mainly, so the arm covering the jacking points is not a problem. But I don't want to bend in the whole sill or underfloor by lifting the car at the original jack points. I found some rubber blocks, 125 by 125 with a 10mm wide and 10mm deep cutout, which I'm hoping will work for not hitting the jacking rail. The sidemember, as seen in the service manual, are the rectangular frame rails that come from the front of the car and go alongside the gearbox and downpipe. Those that get crushed inwards if you use them for a floorjack. They are already slightly bent in from being used to hoist by other people. I think cutting off the jacking points and welding or bolting on a reinforcement plate along the sill might not be a dumb idea. Or is it dumb?     A 2 post hoist is what I'm gonna work with, but not for any underbody work, just leaky engine and exhaust work so far. Depends on what else I find that might need immediate attention. For metalwork on the sills I think I'd just bring the car to a panel beater. What's your take on getting rid of the original jacking rails and putting reinforcement plates along the sills?
    • Yeah titanium always looks cool but I don't need that, just regular pipes would be fine. But I am really struggling to find any full hardpipe kit that is still for sale.
