Needs head gasket .......has many new parts....need cash..loss to much money already...
1990 mx6 2.2ltr turbo auto 4ws $1600
Blue in color
interior perfect
Sunroof
Rhino alarm and immobiliser
k&n pod filter
by-pass valve (makes fluttering noise)
new suspension
new throttle boot
new water temperture sensor
Cd player + 6x9s
2.5inch exhaust
new tyres
155,000kms
recent service plugs, leads, oil filter, fuel filter, oil
+more
turbo checked by turbo specialist when i had a problem which ended up been the throttle boot..and he said the turbo was good..
the car is awesum to drive nice n smooth ...
i can send pics to email if interested or over msn. 0412 215 488 [email protected]
https://www.sau.com.au/forums/topic/70588-fs-mx6-turbo-22ltr-1990-1600/
if you read it he says needs alot of new parts, does this mx6 have an auto or a manual gearbox cause i blew the diff on mine (89 model, auto) and it's gonna cost me 1700 for a new auto gearbox and to put it in, so if it has all the parts for the manual gearbox or if it has an auto gearbox i might take it off ya hands
need cash asap...
as it states it is an auto with heaps of options ibought it for $4500, it broke down the next day due to intercooler piping leakn etc n a few other little problems ive spent about $5500 on it and sik of it..it was originally for work but now i have a better work car (r32gtst) and i just need the cash...its been sitting for a while ever since it broke down n i bought the r32 straight away and wasnt interested in the mx6 anymore...all it needs is a head gasket to run...$500 if you can do it urself..
Cheers Dan
pms replied to. ....i dont think the head cracked ?it has a blown head gasket thats all i no..nrma just tested it and said the gasket is blown...
still looking to sell it for $1600 or thinkin bout fixing it up then selling it.....
ive got no where to work on the car, it is at my sis house..another reason 4 selling...
Come on guys i thought this would go straight away..good for the home mechanic that can replace the head gasket..
i might get interior pics and convince some people
Cheers Dan
  • 4 months later...
    • Man that dinner was such a long time ago....2010! I would only replace the rubber coolant lines with silicone these days; cheap, readily available and will last for ever. You will need new hose clamps though eg https://justjap.com/products/cooling-pro-silicone-engine-heater-hose-set-black-nissan-r32-gtr-rb26dett
    • I wouldn't look too hard at what they did with the R32 GTR in endurance racing in Australia... Lots of things weren't actually available from the factory in the way those cars ran them... Japan also followed what Fred Gibson was doing here with some of there endurance cars in Japan... Australia is also the reason for things like the Brembo brakes, and the change in the gearbox... And quite a few other tricks they used to pull. There's a few other SAU peeps still on these forums that will have heard the stories direct from Alan Heaphy, Fred Gibson, and Jim Richards when we were lucky enough to have a great dinner with them
    • For all the talk of "these parts are junk" I generally recommend OEM because it's really not as bad as claimed. I have never seen or heard of a case like the N63 where the oil returns completely clog with coked oil for example in ~10 years or less. Would it be nice if it were a straighter path? I guess, but most modern cars use a scavenge pump instead of a pure gravity return. Also the factory lines that would be relatively simple to convert to braided are generally speaking hardlines from the factory. I would consider braided line to be a regression, not an improvement. It's also been engineered such that all the hardlines have appropriate strain relief where needed. There's absolutely room for improvement, for example the HKS advantage heritage intake piping shows just how much can be done to make the turbos fight each other less in OEM twin turbo configuration and reduce compressor surge but it's rarely a simple/straightforward process. I recommend looking at what the group A/N1 cars did, generally speaking the changes they made were necessary and proven in endurance racing.
    • Yes, multi relays needed, and possibly a diode. I'm not actually going to think about it though.
