i was there last night and as people were leaving they were doing burnouts
and they werent little half-assed efforts either.
there was big noise and big smoke and it went on for ages.
then the cops showed up and kicked everyone out but they werent defecting
some of em were being real assholes about it
but ill admit some of em were good blokes and were polite and werent on a power trip
they said we could come back in an hour dunno wat happened after that though
So the cops were being ashole too the asholes doing burnouts ? Sounds fair enough to me :D
no they were being assholes to people who were sitting down eating
thats wat pissed me off i was eating and i get told off so did my mates
Dude - that sounds rough - So you were sitting down eating, minding your own business and the Cops hassled you ? That's not right. What did they say/do ?
lol yea probably
we had about 10 cars and i had just started eating and he told me to get up and leave i was like WTF
i go mate can i at least finish my food
he goes no get the fu(k up and go champ
i got smart with him and told him off
then one of the other cops came up to me he was oright about it
he just told me to finish eating and leave and we could come back later
they just had to clear the area
its a good place to check out some nice cars and relax but the lastt few saturday nites ive been there, theres been dicks doing burnouts around the carpark in there mums car etc. there is also a few people causing trouble lookn for attention etc etc.....mr 355 done a nice burnout in the carpark tho..mr 355 is a show car walkinshaw it is nice..
but i mean these guys doin burnouts in a carpark is pretty stupid man..one guy got fkd up wen he did one in his camry or something and the cops were out the front on the road doin there breath tests and the cops walkd ovcer and pulled him outa the as he went to park...
i luv cruising to a place where it packed wth alot of nice cars but these dicks are gonna reck it for every1.
My 2c
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
