Hi all,
Just a quick question...
this may sound bodgy but its only for a test...
Fuel cut on an R32 Gtst, is there a wire from the ECU that i can just cut to stop it?
Or i have to go buy a Fuel cut defender?
Becuase i think it may be the problem with my car ATM.
All help is Appreciated.
https://www.sau.com.au/forums/topic/70637-fuel-cut/
yea... funny thing is... the other day when the car suspension colapst there was no damage.. Yet a get a nail in the tyre, and it ripped up my rear bar.. the nail sticking out kept wearing on the bar.... now it really needs a respray...
Sh!t like that really puts you down about "trying" to keep your car in good nick.
https://www.sau.com.au/forums/topic/70637-fuel-cut/#findComment-1305229
spewing about that man,
as far as cutting a wire to remove boost cut, i dont think its that simple unfortunatly i found an ECU Pinout here http://www.rb20det.com/ecupinout.html had a quick look and only thing i could suggest is to modify the signal on the injector wires, but i wouldnt be game
https://www.sau.com.au/forums/topic/70637-fuel-cut/#findComment-1305666
On the Skylines with unmodified ECU, the first obstacle is a programmed mass airflow limit cut. The airflow meter is not at the limit, and if you modify the signal the car will run lean and probably detonate. The only wire you can cut is the speed signal to remove the 180kph limit. Turn the boost down.... and check the computer diagnostics for error codes in case there is something else wrong. If you want to keep the boost, you will need to have the computer replaced or re-programmed.
https://www.sau.com.au/forums/topic/70637-fuel-cut/#findComment-1310000
Yes yes.... i actually went past Pete @ Atuotech and have it booked in with him to chuck it on the Dyno and see whats happeneing.
So ill find out what the deal is... Boost is goin to drop as Its not to healthy to have that much goin thro until i get some more mods.
See what pete says.. :rofl:
https://www.sau.com.au/forums/topic/70637-fuel-cut/#findComment-1311353
    • Interesting. Some of them were tight to lol
    • That's right, simple but works. Run out of load? Rescale the table lol. Want to be lazy and not rescale? Drag the K
    • @DraftySquash @Duncan he's not talking about the part that sits against the radiator support, he’s talking about the lip that sits towards the front outside of the car. anyway I had a look at other cooling panels and came across this one https://justjap.com/products/carbing-radiator-cooling-panel-plate-nissan-skyline-r34-gt-t?variant=37829684134087&currency=AUD&utm_source=google&utm_medium=organic&utm_campaign=Advanced feed&utm_content=Carbing Radiator Cooling Panel Plate fits Nissan Skyline R34 GT-T (Coupe)&srsltid=AfmBOoonzPDKqe9NgKi5U0AkFc2XvbXETGmNWvfNcyBT5DUZagMYHg9DZ70 if you take notice it’s the same shape.  well thankfully the justjap listing has a description and it says : - Nissan Skyline R34 GT-T Coupe (M/T -07/2000) this means it’s specifically for a s2. S2’s have different front bars to s1 so that lip with the 3 holes are *probably* mounting points for the s2 bar. im not 100% sure but im almost certain it will still fit a s1 bar
    • Everyone is too used to learning from places like HPA "how to tune" and what to expect at what point, rather than being able to see "The computer says I'm in cell with Row = 8, column =4, and I can see my fuel is lean, so lets add more" Everyone wants "real units", which helps for someone picking it up for the first time and seeing how bad the tune is if they're not used to touching it.   However, I think for most of us who want to play with it, you're 100% right, we're only needing to learn about it for OUR CAR. Which makes it great, and we don't need to care what the real values are, we just need to know which cell it is, that's causing the lean or rich point, or that we want more ignition timing or less. But again, everyone wants everything super you beaut and nearly self tuning, with VE maps, and a billion compensations...   Though then there's me over here when I'm doing reverse engineering work just reading data in hex format that most people couldn't work anything out from. Yet I can see what's going on.
