I got my 6 point cage for $550 from a bloke on these forums. Pretty darn good price considering it was for a sunroof A31... which I happened to have. If you can find one locally Id realistically expect to pay atleast $100 a point (in the cage that is).
http://www.sido-takushi.com/mods/safety21cage/
JK
https://www.sau.com.au/forums/topic/70650-full-ceffy-cage/#findComment-1307940
JK
Jaik you got a bargain there, but it was no use to me for a daily driver.
https://www.sau.com.au/forums/topic/70650-full-ceffy-cage/#findComment-1308269
im probly selling the cage out of my ceffy. dont exectly know how many point it is, but it has full bars from front floot to beside the back seats, top bar above windscreen, top bar above front seats, and an adjustable stiffening bar that goes diagonally accross back seat. has full padding to. ex cond.
make me an offer. :P
can take pics if you require.
cheers!
matty
https://www.sau.com.au/forums/topic/70650-full-ceffy-cage/#findComment-1308840
