Hi guys
My clutch is on its way out and i need the part numbers of a new clutch as i might be able to get them through work. I was looking to get an extra heavy duty or super heavy duty exedy single plate to fit an r33 gtst hopefully putting out about 200rwkw after the new clutch is installed. Feel free to offer alternative clutches as i am not just looking a exedy ones. Thanks guys :)
https://www.sau.com.au/forums/topic/70652-clutch-part-numbers/
Hi thanks for the reply. The car is a 1995 series 1.5 (series 2 motor). Have done a few searches and alot of people seem to pretty happy with their different brands of clutches just from what i read exedy seem to be good.
is it a series 1 r33? if so check out nissan patrol cluthces, theres a few theads in the howto faq area, do a search. should be cheap and hold lots of power
if it was my car and i was able to fit a partol clutch it would in a flash. its heavy duty, direct fit and its easily available at your local cap parts workshop. unforuntately it doesnt suit the series 2 as they have different clutch, im sure series 1 is push whereas series 2 is pull and patrol suits the series 1 only. theres a few threads on it, do a search. forget the nice brans if a patrol heavy duty one fits
Yeah had a read im guessing they should be able to hold 200rwkw. Yeah not to sure if it will fit mine cos im just assuming if its series2 engine then it would be series 2 clutch? Is there a way to tell (keep in mind i dont know to much about clutches). What price are lookng at for the patrols clutch under $200? I'll definately look into it if they fit as im not really pushing the power envelope. :)
If going only to 200rwkw I wouldn't go too heavy duty.
My stock clutch started slipping at 209 rwkw only because it'd done 90000 klms - the clutch plate was just totally worn out. I'd say that's the same with 90% of the r33's around with stock slipping clutches.
The stock one should handle 200 at the tyres no worries unless you go silly.
The exedy one I put in is great, although quite heavy (must be a woose) and I'll say unless looking for around the 250rwkw mark it's not an issue.
It was pretty pricey too at 580 dollars.
Cheers
The stock clutch is good for 200rwkw. Anyone else have a stock clutch that is coping well with that. There is probably a good chance that stock one is worn cos it done 84000 on the clock but god knows how many its really done. Im still thinking about going for a heavy duty cos if i can get it cheap i also know someone who can install cheap as well so it might not be to pricey to have a H/D. :D
Cheers
Recommending retaining a standard clutch for 200rwkw is not a smart idea.
If going to the expense of replacing your clutch, you should be fitting a clutch that will hold more power than you plan to make, leaving you with plenty of potential left should you modify your car further.
Hi, My clutch is slipping and needs replacing. I'm wondering about the patrol clutch mentioned and just wanted to know if there was a specific patrol clutch that fits...
Which model, year, etc...
Thanks for any help
Chriso
Where did u get your exedy clutch from? I am in search for a clutch which will hold 220kw-250kw
cheers
Cheers
I just bought a heavy duty excedy clutch for my 95 GTST for $550, its great and does the job. I'm running around 190-200rwkw and was told they should handle 250rwkw.
If anyone needs to do their spigot bush & rear main seal I have a brand new set at home, if someone whats to buy them off me when they do their clutch. Just PM me. I think I paid around $85 for both
Hey you dont have the part number from off the box or anything like that do you. Was it 550 for clutch alone or was that installed as well. :P
I'll try and remember to get the part number tonight for ya.
It was $550 trade price just for the clutch. I installed it myself, so it cost me nothing. Its usually around $600 installation, so it would have been $1150.
Just remembered it cost me $40 to get the fly wheel machined as well.
Thanks that would be great if you could. Hopefully i can get it a trade price to and i know a mechanic that can do the change to. Cant wait. :P
OK i would like to thank you guys for posting is been quite helpful. I ended up getting an exedy HD clutch for $330. The guy said it will be good for everday driving and the weekend track day etc. I know this a cheap price so i hope its not a POS.
part no:
NSK - 6308HD
240 350 HD
Havent installed yet but will try to get it done by next week. Let you k :D now how it goes.
