hey mate,
just a little thing i got told by a clutch dude.
twin plate clutches are expensive to buy and expensive to fix and difficult to get parts for. the japanese dont like to use heavy pressure plates, and therefore to get friction they use multiple plates.
by using an upgraded pressure plate (they can be made to suit your needs) and a heavy duty full face or button style friction plate you can have more grab from a single plate, for a cheaper price and still have the same drivability from a single plate, and will just need a new friction plate should you wear it out.
Paul Thomas has a single plate clutch of the above description in his 400kw (at the wheels) R32 GTR.... thats a good enough product placement for me.
cheers
Linton
If say you had 300kW... and were shifting from 1st to 2nd... the engine is going at ~7000RPM the drive train is going at ~4500 (and your gunning it as you drop the clutch) ...
I've had the clutch slip a few times :S
Normal driving is fine. Low boost is fine... and if you get the RPMs lined up better its also fine ...
Would you expect a $1700 single plate clutch to cope with this?
And on the subject of double plate clutches... how's driving up a long steep road in stop-start peak hr traffic? Currently mine's fairly forgiving :D
twin plates can often snap gearboxes, diffs, transfer cases and the like.. Unless you have over 300rwkw I don't think its worth the damage to the rest of the car, never mind the driveability.
There are plenty of great products sold locally new here that would be equal to much of the japanese stuff, personally I'd just be going for one of them.
  • 2 months later...
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
