  • Replies 154
OK.... so far
Most of you are interested and want to head towards honeysuckle for a bbq and photoshoot..
Then cruise back..
Im thinking maybe a Saturday and then head back and cruise the town that night.
So a full day out would be good. Leave 9-10am head out for a bbq, photoshoot and keep heading for some Awsome scenery for more photos..
And if theres maybe a detour we can take to head back.
Ideas would be great
i'm in provided i have the day off. give me lots of notice!!!! and what about a weekday? does that screw things up for anyone?? just that, in my experience, weekdays are ALWAYS significantly less congested and the fuzz isn't out in so much force.... just an idea but lots of you prolly work weekdays...
d
no no no no no no no no no no!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
bad date for me. seeing that the trackday is on the 1st of may, i suggest that we do it the following saturday on the 7th may. i have filming commitments on that day, and so do FoX, R31DET, Bluprint, Jester.
this way i can get all your cars on tape and keep compiling footage for the DVD. which will be awesome.
your decision anyway guys, just thought i'd tell you the situation.
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
