Hi All,
At first I was embarressed to ask about something as simple as a BOV , but,
after a week of asking all those "In the Know" without resolution , I'm over it!
I have put an RB26 into an R33 auto & everything else is sweet , but , at light throttle / low boost 5 to 10 psi the BOV bounces venting air like a train!
Tried: a number of BOV's both Piston & diaphram style
settled on a Turbosmart Type 2 Vee port
put a vacume/boost gauge on the signal line & checked for Pulses = 0
Tried every vacume/boost source I can find! Fuel reg , boost gauge ,
stepper motor , tank vent canister without sucsess , I even tried "T"ing some of them together..... :cheers:
I believe that the multiple throttles on the 26 is what is giving me grief , I just cant find a source AFTER the throttles that is ballanced.
It cant be that hard..... this is :bs!:
I will donate my vital organs to anyone who can solve this problem
Cheers
Troy Rep
https://www.sau.com.au/forums/topic/70702-bouncing-bov-prob-please-help/
Rep - I don't think you'll be able to find a source after the throttles that is balanced as there is no common area after the throttles due to having individual butterflies. There must be a way though! There's a link to workshop manuals on the SDU site. Thry finding that and the factory position/method may be revealed?
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
    • Are you doing the work yourself or are you paying for labour?
