being ball bearing... if one fails it'll need a new cartridge generally, and sometimes an new comp cover.
Which all added up etc will be over $1200 without a drama if the comp went as well.
If not around the $1100-$1200 non-trade
Thanks guys, I just bought a HKS2535 as well second hand and was just considering a worst case scenario of rebuilding it, i rang ATP and was told that if it needed a full rebuild then it would be the cost of a new turbo which doesnt seem right to me...
Ill appreciate if you could let me know what the prices are... I have the turbo but i think ill have to take it to the tuner and see what they think... fingers crossed all is fine and she makes some good numbers!
$600 for a ball bearing?
i doubt that very much. Or do you just mean that parts themselves?
Mine was 1k falt, that was a new cartridge and everything that comes with it
Also had to machining the comp cover as the bearing collapse caused the wheel to mark the housing, lucky it wasnt too severe
Then it had too be balanced etc. Mine was close to trade also
went around today to see if my turbo is rebuildable
Since my turbo suffered oil starvation most of the shops think there's not much chance that it can be fixed.
The alternative is buying a complete new cartridge from GCG or some other shop over east.
A few shops seem to think there's still a chance it could be fixed depending if the bearing casing is damaged or not. If the bearing casing is damage then I would need a new cartridge if not, depending on condition of shaft and the compressor/turbine blade fixing it range between 500-900
    • Thanks Murray, appreciate the advice, a few things to think about now 😀
    • After my million questions, I'll throw in my 2c now.  If I was in your shoes, I would buy the best/most modern ECU available. A Nexus S3 would fit the bill. It is highly likely that this ECU will last the life of the car, regardless of whatever ECU manufacturers develop in the future. Modern ECU's are amazing and will still be amazing in 10 or 20 years time. If you can get e85 relatively close to where you live, I would buy a flex sensor and size the injectors to run e85. I'd go a Walbro 525 fuel pump with relay wiring kit.  Turbo wise, I'd hit up HyperGear and get a pair of the biggest bolt on turbos.  Now for the safety side of things, I'd have the tuner setup the tune to be very soft/safe on 98. Then on the flex tune, a lot of the timing can be put back in on the top end (I'd run full boost on both tunes, but manipulate the power with the timing). This also has the benefit of hopefully delaying the, "bored now, need more boost" that comes with owning a modified turbo car. If you spend most of your time on the 98 tune, the few times your on e85 will hopefully stay special/fun.  The bad news. As your paying for labour and tuning, I don't think this will happen with $10,000. This might be the motivation to learn to do it yourself though, that way instead you'll have the built car and change from the $10,000
    • Cheers Duncan, on club reg and very much a weekender, don't drive it all that hard and don't intend to go overboard at any point in the future too. In my 40's and quite mature driver, just want that little bit more from it 😉 Sounds like, after ensuring everything is in good condition, ECU, Injectors, Fuel Pump and a set of turbos is likely to be my path forward.
    • 15 years is not too long to hold onto something like that, right?
    • Hey man,   By any chance you still have sunroof for sale ?   Thanks
