some of you may know I recently got my heavily modified R32 4 door :D. Well this is all the information I was given when I bought it:
http://www.prestigemotorsport.com.au/au/st...sp?StockID=2784
Car has come all the way here, gone through compliance and registration etc. I finally got it tuned and dynod last week (217.5 kw at the wheels). On the sheet it was recorded as a GTS4. I thought that was a bit odd and hastily checked the model number on the plate.. RNR32 :D. Some how I've managed to score a 4-door gts4 with an RB26dett, but i'm not complaining :D. I'm wondering if i'm going to need to changing anything because i assumed it was a gts-t all this time :).
https://www.sau.com.au/forums/topic/70754-craziest-import-muckup-yet-d/
it says in the condition report...just under the parts list...."front driveshaft assy just been replaced" that didnt make u think summin was up?
gts-t 's dont have front driveshafts......but hey
awesome luck you have...got a baby gtr.
Yeah the car was reaally tidy actually, only a few tiny traces of rust on the underside where it has been jacked up and one panel not finished properly. It all worked out to be surprisingly close to the estimated cost, although people interested in doing it should definately be aware there are still a fair number of expenses which are expected (like rego and insurance). Definately suggest people budget a few extra thousand over the estimated cost if they want their car on the road within a week or two of it arriving. The car doesn't need anymore braces, it has one in the boot, one in the engine bay (obviously) and one on the underside, very rigid to drive. A couple of things made me start wondering if it really was a gts4 but obviously you'd expect to get a gts-t if you bought a gts-t. the first and most obvious was the AWD light and front torque meters on the dash. But then the car is pretty heavily modified so I assumed they just put a gtr dash in there for fun :cheers:. It seems obvious in hindsight, but i'm not a skyline expert (heck my car is the first skyline i've driven :)). 2 nights ago my mate (who owns a silvia) and I were discussing how different it felt when pushed, especially around corners and that prompted me to check the model number :). It was really the first opportunity to push the car a bit but yeah even I could tell something was very different :). And yeah anything listed on the mods I obviously knew about :), kicking myself about the front drive assembly note though hehe.
But yeah I consider myself realllly lucky with this car :), also came with a carbon fibre bonnet which wasn't listed. Some more pictures if you are interested:
http://www.users.on.net/~ajh/My%20Car/
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
    • Twas your car many moons ago that gave me the idea!
