hey guys im sur you are all sick of this question but im trying to find the workshop manual for r32 GTS-t (RB20det eccs) in PDF format for Adobe
i have searched all forums but am getting really frustrated i need this very soon as in tomorrow but it would be always good to have it on file here anyway
so if anyone can post a link or post the file or email me or PM me or something
most threads are dead now and files and links are not avaliable anymore
basically i need the head stud torque settings and the such as im puttung the head and everything back together over the next 2 days so any help with that would be great
also i have the R32 GTR workshop manual in PDF format if anyone knows if this is the same sort of torque settings as the RB20
if people need the GTR manual tell me how to get it to you ill do it im here to help just as much as the next just let me know how to do it!!!!!!!!!
:cheers:
Matt
https://www.sau.com.au/forums/topic/70775-r32-workshop-manual-pdf-format/
hey mate, cheers for asking, going along slowly getting her right gonna move the battery for the cooler piping me thinks and a rb25 turbo etc so should be fun when shes rolling.
know your itching to get the new engine revving, good luck will be purring soon!!
just need the R32 RB20DET pdf and we will be laughing...dont need as urgently as u it seems but still
well not really omly need it for torque settings but if i cant get it ill use GTR settings no doubt these will be stronger anyway from what i have seen most on the head are a fraction tighter than the RB20 i have an old copy of a manual i found like 6 months ago but was really cut down version and prineted it of but some of the settings are printed so small they are not clear
so if any one can help out i really need to know these settings or im going to torque my head up to GTR settings and prob break shit!!! LOL
lol,
The first file listed is an empty file that states??????
unknown.gif!!DOWNLOAD ADOBE v7.0!!30-Mar-2005 00:43 0k
binary.gif!ADOBE_READER_v7.0!.exe 29-Mar-2005 22:09 19.8M
compressed.gifFCPRO_PowerExcel.zip 11-Apr-2005 14:20 1023k
compressed.gifFC_Edit_Datalogit.zip 11-Apr-2005 14:21 177k
layout.gifR32_All_Engine_Manua..> 29-Mar-2005 22:10 22.7M
layout.gifR32_GTR_Service_Manu..> 29-Mar-2005 23:40 27.2M
layout.gifR33_All_Engine_Manua..> 29-Mar-2005 21:57 23.1M
layout.gifR34_All_Workshop_Jap..> 29-Mar-2005 23:17 48.6M
layout.gifR34_All_Workshop_Man..> 29-Mar-2005 22:07 12.7M
layout.gifRB30_DOHC_Guide.pdf 29-Mar-2005 22:17 324k
You need adobe 7.
EDIT: I zipped it down again to double check. The file is 100% fine. Not corrupted.
cheers mate that helped so much
to everyone else out there first download the Adobe READER 7.0 then download any of the manuals on the list
thanks very much cubes you dont know how long ive been looking for this i owe you big time
  • 3 years later...
  • 1 year later...
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
