Hey Guys,
I have searched all through the previous threads/posts about 32 eyelids But didn't find the answer i was looking for. I know this has been asked many times but seems to alll ways be to no avail. Hopefully someone may know something new?
So please can anyone point me in the right direction?
here is a picture of basically what im looking for.
https://www.sau.com.au/forums/topic/70788-32-eyelids/
  • Replies 61
i had eyelids for a while...
i just taped around the shape i wanted with masking tape and newspaper then gave it about 5 or 6 coats with touch-up paint from supercheap that was a very close colour match...
never had an issue with peeling etc. even through the melbourne winter!
cheers,
Warren.
https://www.sau.com.au/forums/topic/70788-32-eyelids/#findComment-1326165
There are a couple of places that sell eyelids mentioned in this thread: http://www.skylinesaustralia.com/forums/sh...ead.php?t=68543
Including N1 in melbourne, they have them listed for r33 & r34 maybe give them a call and ask if they can get r32?
Good luck!
https://www.sau.com.au/forums/topic/70788-32-eyelids/#findComment-1326471
NismoR34,
I have had this post open for a while but as you can see no real positive response. I had previously seen those threads before posting mine.
I have rang: Jetspeed, N1, Motorware and various importers etc, but no go.
I think spraying them my self might not be such a bad idea, but obviously i would prefer the real thing.
Thanks for your reply anyway much appreciated!
Cheers also to "Interloper" and "Wazr32gtst"
https://www.sau.com.au/forums/topic/70788-32-eyelids/#findComment-1327161
  • 3 weeks later...
Hi all,
Sorry for the delay...the mould is coming along...working on a good mould so i can make eyelid after eyelid with no drop in quality :( there are a lot of 32's out there, and i know that everyone is keen. I will also be looking into arranging professional painting for a few $ more...
Still trying to finalise mounting options so they can be removed if required, and make them harder to snap / steal as I've read that a few people had had issues with people trying to rip them off...
If anyone has a GTR or a GTR gril on their GTST, could you please post up a few pics of the way it (ie - the grill) is mounted as I want to make sure that they will fit GTR's with no modification required.
This weekend i plan to spend a lot of time getting it all sorted, and all things going well they shouldn't be too far away now :)
I'll get some pics up of initial concepts and the like to get your feedback so I can put together something that everyone is happy with. I'll try and get those pics up tonight ;)
If this lot is successful, i might tackle some of the other models too.
I'll keep you all posted with my progress, and if you have any suggestions or pics of what you're after please post them up or PM me :)
Cheers,
Michael
https://www.sau.com.au/forums/topic/70788-32-eyelids/#findComment-1358793
Hi all,
Sorry for the delay...the mould is coming along...working on a good mould so i can make eyelid after eyelid with no drop in quality :stupid: there are a lot of 32's out there, and i know that everyone is keen.  I will also be looking into arranging professional painting for a few $ more...
I'll keep you all posted with my progress, and if you have any suggestions or pics of what you're after please post them up or PM me :D
Cheers,
Michael
Beautiful, Pm me please when there done.
Cheers mate.
https://www.sau.com.au/forums/topic/70788-32-eyelids/#findComment-1362735
Popped d/s eyelid out of the first mould today... needed to modify it a little, so i'm going to be changing this one slightly, then comes the pass side :(
Batteries in the camera are dead, but i'll get them charged up and post a pic up in the dext day or 2 so u have an idea of the shape of the eyelid.
Once I've got my set and i'm happy with them i'll be making a new mould so u guys get quality goods :P
:D
https://www.sau.com.au/forums/topic/70788-32-eyelids/#findComment-1367053
heaps of progress this weekend. I went back to the drawing board and started again..ended up with a better result.
All that's left is finishing (sanding back etc) and i'll have the first set to show off :rofl:
The car is in a few pieces for another cause, so i took a pic with the h/l out
https://www.sau.com.au/forums/topic/70788-32-eyelids/#findComment-1379910
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
