  • Replies 61
hey guys,
I should have my set sanded this w/e. haven't had much time this last week with changing jobs n all, and i've been crook which doesn't help matters any.
Let me know which type you guys would prefer...if you want ones that just stick on, i can put them together pretty quickly, and it will only use half as much fibreglass, so i can sell them cheaper ;) If anyone wants the stick on type, i should be able to put a set together this weekend (unless I keel over from being sick ;) ).
Once i have my bolt on set trimmed to fit, i'll see how they go with the bonnet...but i can't see there being any issues. They will bolt on at the back, and I'll probably be sticking them at the front so thieving little s**ts can't get their fingers up underneath to rip them off.
**PM** me with what you guys are expecting to pay, and i'll try and work my price around that :) I'll also work out how much i'll need to charge to cover my costs ;)
I trial fitted the eyelids to the car last night after trimming them, I need to shave a little off the face of the pass side one to even things up.
They fit and the bonnet closes normally. The little black rubber things on the bonnet were originally hitting the eyelids but I trimmed it (edit: by "it" i mean the eyelids, not the black things) back and now fits with no issues :P
Also tried to "steal" them with the bonnet closed and they weren't going anywhere :D
All that's left to do is:
*sand the pass side eyelid
*make brackets to fit
*paint
Once i have this set completely finished I'll put a post in the F/S section :D
To give me an idea of demand, please PM me or post here and let me know what you guys want:
*stick-on (will just cover the top & face of the headlight), or
*bolt in (covers face and entire top of headlight)
:P
Michael
Man, i'm interested too if you're going to start making more lol. Been after eyelids since i bought my 32, makes it look so much "Tuffer"!
A bit off the topic, but how do you's get that little pic of your cars in ur info thing? I've taken pics of my car with my fone, but cant work out how to put it up there!?
Let me know how you go with the eyelids i'm VERY keen.
Michael is thinking of gettin' a GTR so it isn't goint be cheap ;)
:rofl:
will trade for GTR Parts ;) hahaha if everyone donates something (a caliper, a radiator, an engine, etc ) I should be able to build a GTR by 2010 :wizard:
but seriously, I'm going to make 2 or 3 types.
1- Stick-on ones for maybe 50-60ish (to be confirmed) - these will just cover the face, an dif someone was so inclined may be able to be ripped off :(
2 - Stick on that are a bit bigger and will be hard to steal because of the way it is moulded around the headlight,
3 - And the 3rd type which will bolt at the back, and can be stuck at the front (so they don't rattle around and are a bit more secure :) This is the type i have made and basically ready to be painted.
As per one of my previous posts, i tried to "steal" the 3rd type from my car with the bonnet closed and it was impossible. Also I couldn't get enough leverage to break or snap them off because they are moulded so closely to the headlight :D
If no-one wants the cheapies then please let me know and i'll focus my efforts on what you all want :) Even better if you could email me which type you'd prefer @ Midnite_Garage at hotmail dot com it will be easier for me to keep track of what people want. I'll let you know set prices for type 2 and 3 sometime next week when i have pics.
:cheers:
Michael
    • Any number of different ways. Have the coils draw sufficient current to provide contact wetting. Use different contacts in the switch, either by material or design, better suited to the low current drawn by a relay coil. Etc.
    • Hmm, how does the R34 manage to have headlight relays then without getting excessive carbon buildup on the headlight switch contacts?
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
