Hi guys just wanting some help.
I was just wondering apart from the obvious how can you tell when a turbo is on its way out?
Does it start to get louder i.e. you can hear the turbine spinning easier?
Just after some info so I know what to look for or hear.
Many thanks
By the way I have a 97 series 2 R33 with 87,000 on the clock.
https://www.sau.com.au/forums/topic/70830-turbo-noises/
Common symptoms and conditions:
- Turbine Seal Leak: White smoke in exhaust, bad O2 sensor readings, Oily exhaust pipe, black oil due to excessive blowby.
- Compressor Seal Leak: Oil in intercooler piping and Throttle Body, also white smoke out the tailpipe.
- Damaged compressor or turbine wheels: loud sounds, vibrations and chunks of metal coming from the turbo.
- Damaged bearings or bearing failure: Decreased boost levels, increased noise and vibrations, usually accompanied by more smoke.
Those are all the major problems that turbos have.
https://www.sau.com.au/forums/topic/70830-turbo-noises/#findComment-1306262
