hi - ive got lots and lots of money and i need to buy parts !! ha ha
i need some help with sourcing parts for my T70 turbo Ceffy..
i am after
*driver side window motor and regulator (URGENT)
*rear seat (grey/black)
*centre gearstick garnish (manual)
*passanger side airvent
*centre climate control garnish
please get back to me with any info
much appreciated
shaun
https://www.sau.com.au/forums/topic/70869-wtb-ceffy-parts/
