  • Replies 54
Id rather just have to replace the window after a break in then find my car missing
Thats for sure . By the way if you get one of them dont lock it in 5th ( they can drive in 5th no worries ) , lock it in reverse .
Dont mean to be rude guys. But the guys that are in Sydney and have a tracking system give your tracking company a call as my tracker doesnt work outside the metro area. As soon as you get on the F3 just after Hornsby there is no more signal until you get to Newcastle. And heading South I think Wollongong is the limit as well. I only know this as I sold a car with Quiktrak to a guy that lives in Terrigal and he rang them and they told him it was useless to him as there is no coverage there.
Thats quiktrak , they don't have any cover outside sydney at all and its old technology .
The latest trackers use gps to track ( as long as its above ground you can track it ) and gsm to communicate .
With the gps tracker you dont have to pay annual fee you can track your own for the cost of a phone call.
That sounds cool. Much better than the old system.
We have all our fleet at work tracked using the satellite/ gsm system and it is a wonderful piece of gear.
We have a pc with large hard disk space that was included in the package which we are able to "live track" the vehicles when they are on the road to see there position.
If we dont live track the vehicle, as soon as it returns to base it auto downloads its days events through the aerial we have mounted on the roof of the depot.
In relation to systems that dont get coverage everywhere, we originally had this system years ago and as mentioned dont use satellite technology.
They work ( well ours did) on the old analogue/cdma mobile phone towers and triangulated your postion from the nearest 3 towers hence when in remote/rural areas we lost track of the vehicle.
Just wondering how they drive it in 5th?
My car is stuck in 3rd gear at the moment and I had trouble hill starting (smelt burning clutch heh)..
You cant drive it in 3rd gear ? you got to be kidding !
Do you think the thieves will care if they burn your clutch ? They take the car away then cut the lock when they get their grinder going .....
Lock it in reverse and they cant get far ...
these tracking system's seem almost bullet proof how ever i wonder if its worth getting that system when you have full-insurance!!!
Don't forget you buy insurance just in case you don't want to use it though .
If you have a high performance car stolen it will be hard to get insurance again and if you do can you imagine the price !!!
If its stolen and recovered you are going to be out of pocket as well , most people would have high excess for theft .
Some insurance companies will give you lower premium if you have a tracker , mine will not cover me without it .
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
