Hi everyone,
I'm waiting to pickup my R33 GTS-T from the previous owner and there was one question he couldn't answer about it.
The unit has an inbuilt LCD screen which controlls the sat nav, cd stacker, am/fm radio, audio equaliser and TV Tuner and, yes, get this, tape deck!!
I didnt check for the brand when I test drove the car, but later on when I spoke to him he said it was a Nissan branded unit.
Has anyone else seen one of these? I'd like to get as much information about it as possible, a manual would be even better!!
Any help appreciated.
Thanks,
Mike
https://www.sau.com.au/forums/topic/70879-sat-navtv-tunercd-stacker/
yep they are lots of funs to remove and the stacker is a sony A30 unit. they are indeed factory fit on these cars and removing one involves a LOT of rewiring as EVERYTHING is tied to a module behind the rear seat. can't remeber the make of the actual unit but clarion ( denso) rings a bell for some reason.
as usual the nav/tv wont work here. the stacker will be on its last legs as well.
have fun..
have fun..
Hi Chris,
The unit has Nissan CW726 written on it. It has a 7" (approx) screen that shows either current radio station, cd stacker info, tv or input from the front mounted a/v inputs. The stacker itself has Nissan written on it too, and its a six stacker.
Any ideas on where I might get information on it, google returns one link (in japanese) and thats all.
I dont think its a Clarion unit as I believe those units allow the screen to retract into the dash, this screen stays out all the time although the angle is adjustable.
Mike
its a clarion unit. ( the aftermarket clarion is motorised these arent.) nissan have used clarion in most of their cars for years. the only exception seems to be a xenavi item I worked on a while back.
Hi Chris,
Ok, thanks for that. So I guess I could try Clarion for some info. I'd like to get hold of a schematic diagram or service manual, at least that way I can see if it can be modified for PAL.
Mike
Hi Chris,
Mike
Check this thread here for a link to a company that does PAL conversions:
http://www.skylinesaustralia.com/forums/sh...ead.php?t=67425
is it possible to get a dvd player to hook up to the tv that accepts pal dvds but converts to ntsc for the jap tv?
It may be possible, most of the current home DVD players can be set to output either PAL or NTSC irrespective of the DVD type, so you'd need to make sure the car versions do the same.
For me it wasnt about DVD tho, i was thinking it would be cool to be able to listen to the V8 Supercar races if I happened to be on the road at the time of the telecast.
mike
Yep, there are more than a few in-car DVD players that do just that, they have an NTSC video output on them so that they can be plugged into OEM screens that have a video aux-in connector.
Can you suggest any reasonably priced (mp3 + tuner) models ant?
best I've come up with so far (price/value/quality wise) is http://www.jvc-australia.com/products/_pro...ils.asp?ID=1397
ok that changes things:
try this:
http://www.audioexpress.com.au/shop/item_s...?code_no=VS9910
price ( I need to update mine) is $1900
I already have a ntsc tv that came with nav system. Want a single din unit that accepts pal outputs ntsc + mp3 + tuner. Similar to this http://www.jvc-australia.com/products/_pro...ils.asp?ID=1397
If you aren't too worried about the brand, found the following after a quick google search:
http://www.strathfield.com/Products.asp?CatID=186
There are plenty of similar cheap no-brand units out there.
Though that JVC unit is pretty good value for money I reckon, cheaper than some high end CD units I've seen!
  • 3 weeks later...
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
