All rebuilt...runnin in...finally get a few k's on er and give it a bit.
Doesn't really splutter, more of a hesitation
Feels like it wants to go, but mellow's out.
Goin at 0.6 bar steady..so I don't think its leaking.
I have a nisdat..timings ok, oxygen and af sensors seem fine.
It doesn't seem to retard as though the knock sensors are kicking in.
New battery, newly flowed infectors, new plugs...like I said it doesn't splutter like a lack of fuel or spark.
At a guess its electrical...any thoughts
https://www.sau.com.au/forums/topic/70904-rebuilt-gtrnot-enough-go/
Mine feels exactly the same.. Basically no notisable problems just no power..
Id get it on the dyno and see how much power shes putting down and check the af's.. PM me if you find the problem .. :spank:
yeah about 600..but I still would have thought as revs pickup power would too.
Another strange thing...my boost controller doesn't work now...but electrically does.
Something is cutting, I'm sure of it..fuel,boost??
Weekend will reveal I hope. Got a new fuel pump happenin and another gtr to swap stuff.
If I'm game, i'll free boost it in 3rd and take my foot off as soon as it goes over 0.7 as it only does 0.6 now.
sounds like boost leak or boost control issue, are all inlet hose fitted correctly??
very easy to miss a hose!! i have recently fitted a brand new engine to gtr and
tight will very little effect on boost achievable.
i also doubt fuel is issue.
it really does sound like leak or control issue, maybe turbo actuators partially open.
also check that you blo off valves are not leaking.
cheers russell
Has the engine been run in properly?
I wouldn't be reving upto 6k inless you have done atleast 1,000k's.... Before then you should be reving to 3k.
Lots and lots and lots of theorys on how to run an engine in...
But yeah, Id say how all your little hoses are hooked up, just if stuff was working before, and isnt now, its more than likey going to be something small that would be easy missed. Such as forgetting to put a piston in, thats big stuff, it just wouldnt happen. Putting a little hose on the wrong nipple, thats easy as to miss.
thats a myth
My car, bedded in on the dyno, and been runnning 16psi ever since, 7800rpm limiter no probs
nearly 6000km's and i have no problems. car runs fine, makes the same power as it did from day one.
thats a myth
Didn't you have a turbo problem :cheers:
    • Just a follow-up on this topic. From what I can tell so far the rusty residue on the engine block might be unrelated to a coolant leak or maybe just older than anticipated. After driving it from the winter garage to my friend's garage I could not see any new traces of coolant leaking there, but I will test this properly once I was able to fully warm up the car and drive it for a bit. I think I can agree that the whole porous engine block stuff is kind of nonsense, but there is just a silly amount of true, false and half-true information on anything Skyline-related on the internet.
    • hrmmm , not mine , easter plans to pull engine not happening
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
    • Quick update.  The engine grounding strap was replaced, the engine is now happily running.  Tested the voltage drop before replacing the strap, was about 1.2ish volts down between engine to battery, chassis to battery. With the new grounding strap, pretty much no voltage drop at all.
