G'day.
Just wondering what everyones doin tonight.
Anyone wanna organize a bit of a cruise??
If anyone has a map they wanna use or anyone wants to make one, feel free, cause I really don't have anythin planned.
Catch ya,
Ben.
(Last nights cruise was awsome, but my girlfriend wouldn't let me go fast. :D So I wanna do it again tonight)
https://www.sau.com.au/forums/topic/7093-doing-anythin-tonight/
hey hicks man when u say orragon road do u mean orrong road? just curious cos it will be more convenient to just tail you guys from there cos its closer to my joint...not sure if I'll definitely go yet cos I got no money and no fuel, gotta try score some dosh of people that owe me lol
Cruise 7/12/02 Call Ben on 0407 105 004
2100/30
Meet at leach hwy Mcdonalds front car park
Left onto Lach hwy
Left onto Orragon Rd. (somethin like that, its the next left past welshpool rd)
Onto Grahem farmer and through the tunnel
Exit freeway south
Exit Riverside drive
Left onto barrack st
Left onto St geoges tce
Left onto Fraser ave and park in main carpark.
Re Group
Exit fraser ave left onto kings park rd.
Left thomas st.
Right stirling hwy.
Right stirling road.
Right at round-a-bout Shenton rd.
(T-junction) Right onto Stephenson Ave.
Left perry lakes drv.
(T-junction) Left oceanic drv.
(Lights) Right west coast hwy
Left scarborough beach road
right @ round-a-bout
Right @ round-a-bout
Left onto west coast hwy
First left at lights into car park.
Re Group
From here i've got more, it just depends on how much driving you wanna do.
Just meet at maccas, and we'll saught everything out.
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
