insane im there, went 2 caulder one friday night 2 weeks ago for street drags..... some of those people need to just not show up, but hopefully this w/e will be mad if supra clubs and lots of 'liners and other imports show up. im new to the whole skyline experience, so i pretty much luv everythin about them.
but im gonna have to bring my mates along and check it out..... im thinking i should get my mates "fully awsome" * cough cough weak as piss * lancer out there for my own entertainment and everyone else hehehe, its sort of a mean thing to do.... put your mates 4 cylinder non-turbo'd lancer out there against sum wicked high power imports.... but it might bring him down to earth and make him realise..... he should be steerin a nissan ... or better yet a skyline... round town instead. :headspin:
oh, does anyone on here know of someone, or is that someone.... who drives a '33 mock up of the GTR thats on 2 fast 2 furious??, saw it on the way home from drags 2 weeks ago late at night... first at taylors lakes maccas, then on the caulder freeway headin back 2 sunbury.... wasnt exactly the same as the 2f2f one, same color though, with pretty much identical graphics, oh and it was a '33 not a '34, but if anyone knows the dude that was drivin it, or is that guy, send us sum pics plz, it looked mad from what i saw.... that and no1 believes me when i tell them about it.... they think i was seein things :D
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
