i got this is a email a moment ago.. maybe worth a try??
Petrol prices - worth thinking about!
I called the number on the bottom of the email, and it is for real. This initiative does come from Barry Minster, worth calling and chatting to him if you need reassurance.
Apparently we are going to hit close to $1.35 a litre by the winter. If this happens the prices will flow on down to the price of every thing we buy! Want petrol prices to come down? We need to take some intelligent, united action. Philip Hollsworth, offered this good idea.
This makes MUCH MORE SENSE than the "don't buy petrol on a certain "day" campaign that was going around last April or May! The oil companies just laughed at that because they knew we wouldn't continue to "hurt ourselves" by refusing to buy petrol. It was more of an inconvenience to us than it was a problem for them. BUT, whoever thought of this idea, has come up with a plan that can really work.
Now that the oil companies and the OPEC nations have conditioned us to think that the cost of a litre is CHEAP at .89 / .95 cents, we need to
take aggressive action to teach them that BUYERS control the marketplace not sellers. With the price of petrol going up more each day, we consumers need to take action. The only way we are going to see the price of petrol come down is if we hit someone in the pocket by not purchasing their
Petrol!
And we can do that WITHOUT hurting ourselves.
Here's the idea:
For the rest of this year, DON'T purchase ANY petrol from the two biggest oil companies (which now are: BP and Mobil). If they are not selling any petrol, they will be inclined to reduce their prices. If they reduce their prices, the other companies will have to follow suit. But to have an
impact, we need to reach literally millions of BP petrol buyers. It's really simple to do!!
Now, don't wimp out on me at this point...keep reading and I'll explain how simple it is to reach millions of people!! I am sending this note to a lot of people. If each of you send it to at least ten more (30 x 10 = 300) ...and those 300 send it to at least ten more (300 x 10 = 3,000)...
and so on, by the time the message reaches the sixth generation of people, we will have reached over THREE MILLION consumers!
Again, all you have to do is send this to 10 people. That's all. (and not buy at BP and Mobil) How long would all that take? If each of us sends this email out to ten more people within one day of receipt, all 300 MILLION people could conceivably be contacted within the next 8 days!!! I'll bet you didn't think you and I had that much potential, did you! Acting together we can make a difference. If this makes sense to you, please pass this message on.
PLEASE HOLD OUT UNTIL THEY LOWER THEIR PRICES TO THE 80 cents a LITRE RANGE.
It's easy to make this happen. Just forward this email, and buy your petrol at Shell, Caltex, GAS. or Gull Outlets and drive past BP and MOBIL Stations.
https://www.sau.com.au/forums/topic/70964-petrol-plan/
Had this in the UK and it made no difference. It went round some huge forums there but the price stayed the same. As others have said BP and Mobil are the two best performance fuels anyway. The kind of people who would make in impact if any is the family people who just use ordinary unleaded and are not too phased by the petrol type.
https://www.sau.com.au/forums/topic/70964-petrol-plan/#findComment-1309170
I'm not saying it won't happen, but I received an almost identical email to that, last year. At the time I thought it could work too, but realistically it's unlikely we'll see the good old days of .80c p/ltr (maybe if BP had coupons, hehe).
Has it crossed anyones minds it could be a marketing ploy by the other service stations??
If we all start boycotting BP & Mobil, there'll be a lot of sick :spew: running imports on the streets.
https://www.sau.com.au/forums/topic/70964-petrol-plan/#findComment-1309223
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
