SAU Victoria Newsletter - Download available here
Hi GuysGirls, available below are the SAU Victoria newsletters. These newsletters are produced every two months and contain information on things like SAU Vic events, SAU Vic event wrap up's, members only deals and event photo's just to name a few. This thread will be updated on a regular basis so check back for updates as it's well worth the read!
For best results right click the required link and select "save target as", then simply selct the location you wish to save then sit back and relax while it downloads. These newsletters are quite large so 56k users will have to relax that little bit more :)
Note you will require Adobe Reader to view these documents which can be downloaded from here
Top effort guys. Just two months on from the last one and the difference is huge.
Should have asked for the orginal pics and I would have sent them through or at least edited the plates a bit better!
Also - if anyone has any articles, pix, for sale items or just want's to pass on some ideas - please do so :D
[email protected]
And yeah, sorry for just swiping pix :devil:
Will do a photo credits section next issue.
Rigga: The puzzle was in last issue (without the answers) :)
heartbrkr: My bad on the final editorial - got a bit pushed for time. And the GT4 promos are called 'filler'. I need more submissions - hint hint :D
  • 2 months later...
Just to let you know that the guy who does the newsletter has finished it, but is just having trouble exporting it to PDF because his computer is an old pile of crap.
Will be up by the end of the week - apologies for the delay.
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
