I was under the impression the 4 door was a little longer.  Is this true.?
I'm just trying to source a 2nd hand one as mine has a fault
Thanks
The only thing longer about the sedan is the boot is about 100mm longer than the coupe, the wheel base, etc is the same as the coupe. I replaced the tailshaft on my sedan a couple of weeks ago, sourced one from Just Jap. They assured me the coupe tailshaft and sedan tailshaft were identical. Sure enough, it all bolted up no problems.
Hope that helps.
Hope that helps.
So you have a sedan? That's good to hear it shares the same wheelbase and tailshaft.
Thanks for the advice.
Cool. Yeah just checked your photos out. Looks nice. The sedan is pretty practical. Mines only a series 1 but I like it.
So the R34 cooler went in ok?? Did it pretty much bolt up? Did you feel any power/torque difference just from the cooler?
You have/had a lot of skylines!
Did just jap supply you one in good condiition? Was yours causing vibration? Mine is!
I checked the wheelbase in the manual - sure enough you're right!!
The 34 cooler bolted straight in, its a fair bit larger. The only problem I had was refitting the inner guard, cause the 34 cooler hangs a fair bit lower it was a VERY tight squeeze but it all went in. I actually did think I could feel a little bit of difference but honestly it was prolly just me wishing it to be faster, not really sure. I will be dropping it on the dyno soon, that will tell me for sure :D .
I had the same problem, a bad vibration at hwy speeds. The centre bearing was pretty average and the tailshaft had taken a bit of a bump at some time. The one Just Jap supplied was fine, was pretty clean and it fixed my problem, runs nice and smooth now. I think it was about $295ish ??? I fitted it myself, took about 45mins.
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
