Stay away from it it dont steam, and once my seats are dry i might be able to tell you if it cleans......might.
I did what it said, spray area, pull trigger, rub back and forwards 2 or 3 times then release trigger for super fast dry action. Rubbed back forth 2-3 times.....after $6 worth on one spot of "super fast drying action" moving back and forward i gave up...
You could achieve similar results by throwing a bucket of water in your interior.
My seats are wet, i spent 1hour with sis hair dryer drying them out best i could, hopefully its sunny tommorow!
Moral is - IT dont work!, Dont try it!
https://www.sau.com.au/forums/topic/71024-steam-cleaner-at-fyshwick-car-wash/
Who do you complain to its all coin operated unmaned?
I now have water marks/stains around the edges of the seats. And all i wanted to do was put a nice finsihing touch on a sucesful install of my full GTR interior :cheers:
Im planning on lodging a complaintive letter.
Just complain. They will probably get it detailed for you. I had a car wash incident similar to that and they made it all good.
Oh these places usually are manned in business hours and if not the contact number is usually on the service door.
You shouldnt use those dodgy interior steam cleaners, I was a car detailer for over 2 years and I will only use something like a Britex with proper interior shampoo, its not a steam cleaner it a wet vac = better results, quicker and if you get a couple of mates together and hire one from Woollies and do all your cars its pretty cheap.
If you want the easy way out go to Advanced car detailing in Phillip and get an apolstery clean for around $100 <--- Its worth it if its really grubby!
The interior isnt that bad, i just was so pleased with my self with a sucessful change over from stock gts to complete gtr that i thought i would top it all off with a nice lil stema clean........
This at car lovers?? i used it to clean my whole interior, did a mad job, for only $10!
Maybe it was broken or something?
Must be, coz this was terrible, did everything but clean, i now have water marks all over the seats :D
I must admit, it didnt remove everything, but it cleaned off the marks that a vacuume cleaner couldnt clean off (chocolate icing powder) and did an awsome job of it... unlucky to hear about your experiance, wouldnt suprise me if it was broken as so many people treat others property like shit!!!
Sorry 2 hear about your watermarks man
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
