Definately not fit without pods.
I have 6.5" and it needed a huge spacer (can't remember would have to measure the mdf) to clear the window when it was down.
I wouldn't even put a 6x9 in it but that's just me :P
Door panel should be easy, just undo the door handle inlet, unscrew the door "handle" (the part where you put your hand into when you open the door), unscrew the few screws on the door (some are covered with a plug only visible when the door is open), then just pop the others off.
I removed the plastic crap from the door and cleaned all the goop off when I was there and replaced it with sound deadener as well.
I think I have some photos when I did mine if you get stuck.
Hope that helped :cheers:
I wouldn't even put a 6x9 in it but that's just me :D
Hope that helped :P
Thanks dude...i'll prob. go 4 d 6.5" ...hope i dnt encounter any problems...
is its stock speakers 6.5"?
6 x 9's do fit ...i have got em in mine ....try find the smallest 6 x 9 u can ......the kenwood 3 ways 250watt work. the big 6 x 9's wont fit (depth wise) ....
it takes a lot of fiddling around to get it to fit and make up a pod that fit the space...(out of mdf)
then u have to sound dead every fricken thing ...to stop the door vibrating....
Sound good though ....i ahvent even don the rears yet... they are still the crappy 6's ...
yea the3 stock ones are 4 x 6 in the front
