I have dealt with Doug at NPC a fair bit, I had a Twin plate Exedy RB clutch rebuilt by him. Great guy to deal with and knows his stuff
NPC can build you a 250rwkw plus, single plate for approx $533.
Thay also build thier own twin and triple plates clutches from scratch
twin plate is about $1700 fully rebuildable
They have a few in GTR's with great results
  • 2 years later...
  • 2 months later...
we run an npc clutch in our car! twin plate billet job. amazingly strong but light clutch pedal
never ever slipped and we actually fan the clutch often on motorkhanas!! as race use we have been getting the whole year out of it, which means over 180 launches from above 5000 rpm.
maybe a little more than you require though
i side-step mine at 9500rpm....no probs...grabs hard and gets me over the 60' in 1.41 secs!
this is in a 500AWKW 9 sec drag car.
no hint of slip yet.
  made_guy said:
Hey Pal - what brand ceramic did you get?
sorry for the late reply. dunno about the brand as it is a NPC ceramic single plate clutch, far as i know it is a modified R32 GTR clutch. had it in a few months now and ended up getting a billet flywheel as well. I can highly rate these clutches, lovely to use on both street and strip (just need better tyres now as they spin 1st and 2nd).
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
