They will tune it on the road no need for a dyno if anything Ben may suggest that he touch up the top end on a dyno becuase of the speeds on the road . I have same amount of mods as you bar the cams and I'm running 2530's which are alittle bigger then gt ss and my car was tuned 100% on the road with no problems by Ben .
Your looking at around the $400 mark which is good value I remember CRD wanted $1200 when I rang them . The boys at Bel spent about 2hours on my car at no extra charge before they even began tuning to make sure everything was spot on . CRD are good and have the runs on the board but they know this and they are alittle on the expensive side . I was doubtfull and unsure about taking my car to Bel's when I was looking for a tuner specially with the whole road tune thing but I'm glad I did in the end .
It's your call at the end of the day but I suggest you go and talk to both before making a decision .
  • Replies 106
My car came from Japan with a tuned factory ecu, I was to scared to keep it because of the myth about there better fuel etc so for the couple of months I had it before I bought a power fc I was only running low boost and never knew what the factory ecu was like
I purchase a power fc and booked the car in for a tune with BEL as they had looked after me with fitting other parts and servicing the car, I let them road tune then as I was a bit concerned about road tuning only I had them finish it off on the dyno we made 280rwkw which I was happy with but then as I drove home and raced it once I felt it was lacking so I booked it back in on the dyno to do a before and after comparision with the factory ecu and power fc which I should of done from the beginning
BEL's tune made power 100rpm earlier then the factory ecu but sadly was 48rwkw less and other then the 1st 100rpm the factory ecu made more power and torque everywhere, it ended up that the factory ecu was tuned very well and didn't show any signs of pinging or leaning out
So to cut a long story short I wasted $700-800 by the time I paid for road tune and dyno tune and dyno time as you have to pay the dyno owner aswell as BEL because they don't have a dyno all to loose power
Brett
Hitman in Penrith done mine......Road and dyno tune...
VERY happy with the results.
Just a reminder though.....no matter how good a tuner is they can replicate 100% of what happens in the real world...so you may get some areas that need to be ironed out after the initial tune....since hitman is close to my house I have been back and he has spent a few minutes in the car with me ironing out the problem areas....all free of charge.
ok its not a GTR....but I dont see what the difference is when it comes to tuning.
I've had a few cars tuned by Ben at Bel.
They did a road tune on my GTR. but the top end was getting a bit hairy on the street, so he wanted to clean it up a bit and lean it out on the dyno. I ran the car at WSID after just the road tune and did a 11.6@120MPH.
Bel took it down the south coast to a 4x4 dyno and it only needed about 30-40mins spent on it. Ended up making 290kw. (still running fairly rich AFRS)
At compak attak, the car ran an 11.3 and was trapping 124mph. A bit more fuel can be taken out at the top end and it will make a touch more power.
I've also had a couple of Subarus tuned by Bel. My old STI (street tune only) was stock except for PowerFC and exhaust and was running mid 12s and trapping 111mph. Lots of guys spend big dollars on WRXs and still can't get into the 12s.
Bel have tuned quite a few GTRs from this forum. I can think of at least 7 or 8.
The funny thing with tunes is that unless something major goes wrong and you get a tune from another tuner you've got nothing to compare it with, so you may be happy with a mediocre tune and never know its mediocre as its all you know
In my experience if you want a nine or ten second car pick a tuner that has the experience with tuning this level of modifcations as if you don't all you will get is another mediocre 11 second car and tune and waste your $$ like I did
Sure 9 out of 10 of the tuners mentioned in this thread can tune but to what level they can tune is another thing, if your happy to be just another 11 second car use them but if you want that edge like TWO 06l has running 130mph or me 128mph think before you pick as that extra 48rwkw could be the difference between you being mediocre or at the top of your game
Brett
And if you want to start comparing. My old MY00 STI trapped 111mph. Stock except for Power FC. Still running JDM standard boost levels. ECU tuned by Bel.
Another MY00 STI. Major mods. Big apexi turbine with external gate, 2.5L bottom end with forged pistons and rods, front mount, 1.6bar boost. Power FC tuned by CRD...this car traps 112mph. How could I not be happy with mine?
What about Butthead's BCNR33. Had the works from Japan. 2530s, 550cc injectors, full exhaust, dumps, cam gears, HKS fromt mount etc. Power FC tuned by CRD...could only trap 110mph. wrxhoon's old BCNR33 stock except for N1 turbines and Power FC trapped 121mph. Butthead had his retuned by Bel...ask him how it goes now.
Oh...did I mention that wrxhoon's car used to get 8km/litre fuel consumption?
You can't compare my car to TWO.06l. Mine has a good 200lbs on it for a start. My car runs air cond, power steering and clutch fan. I also ran my car in full street trim. Cat converter, quiet exhaust, straight optimax, only 1.3 bar boost, spare tyre etc. I know I could gain more average power by running decent fuel, putting in a bit of timing up top and pulling some fuel...but it's street car so I don't want to tune it for race fuel.
Also, in the end, I couldn't care less what power my car makes. So long as it has the response I want and has good average power, I'm happy.
Nothing against CRD at all...but in the end, there's no such thing as a perfect tune, it's not rocket sience, all you can do is change AFR, timing and boost until you get the result you desire. I've always been happy with Bel, because they don't just tune for power, they take the time to make sure the response is good everywhere.
Sorry but I think road tuning is a nightmarishly thick thing to do or have done. No doubting the results as many have achieved good times and made good power with road tunes but come on, safety first no?
Adrian
Once again, BEL only tune power FC's. I am sure any decent tuner who specialises in ONE particular type of ECU will be at the top of the tuning tree for that particular ECU. Their are only a handful of (Sydney) tuners that would be able to tune any car with any ECU and engine set up. I am sure that you can specifiy what type of tune that you would like the car tuned for and these tuners will oblige.
Comparing two different cars with two different sets ups and tunes isn't the same as comparing the same car with two different tunes.
A (public) road tune is good for responsiveness and drivability, but I don't like the low safety aspect of it - no matter which road is used.
what about the way the car is driven on the road tune, what governs the thrash factor? I would be really nervous about someone going full tilt in my GTR without knowing them personally? does anyone here drive the car for the road tune with BEL? or do you just leave the car in the lap of the gods and pray it comes back with tyres clutch and engine :rofl:
I am leaning towards BEL right now, but want to be sure!
Are most people leaning towards BEL coz of the price factor now???
As BU5TER said, you need to get a car tuned by a number of tuners before you can compare. I guess I was intially asking if anyone out there had the same car tuned at different shops for a better comparison.
It sounds as though both CRD and BEL get a good wrap but money is a big factor here.
Also, I don't like the road tune...it's too unsafe...Especially at the speeds reached by these cars.
Brett
Not wanting to start a shit fight here but is it not true alittle while after replacing the factory ecu that the engine failed ?.
At the end of the day I soppose you can't go too wrong with either tuner . Another one of my pet hates is people who think they are on another level to everyone else which is the feeling I get from CRD every time I have walked into the place unless you are willing to empty your pockets. I soppose they need to do this though to sort out all the time wasters that come with running such big well known performance shop .
Yeah it did fail all but 2 years later after having its arse raced off for those 2 years, after we stripped the engine down it was dead stock bot end including head gasket so imo it done pretty well running consistant 11's at 128mph in full street trim and pushing 300+rwkw for that long
What times/power/mph do you run?
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
