  • Replies 49
ok Compressor housing has = 49179-52010 and exhaust housing = Z9-11100....means nothing to me lol....hope this helps....
Cheers,
Michael
does it have any numbers inside the bottom of the housing cause thats were most turbos sizes are
mate very interested. just wondering how much bigger than the stock tb25 turbo this is? i have a t4/t3 turbo and my engine flows way to much air for it! also what offers are u willing to accept? and lastly what is the go with that adapter? is it origionally of a rotar or somthing? cheers, alex
PM sent....
