this came with the car i bought but i cant afford to put it on so ill be sticking to the stock t3 for now im selling it coz i need cash quick
it has a v band flange at the back so no welding, clamps onto the dump pipe
oil cooled
T70 ball bearing turbo
shaft and wheel trim 64.5mm
compressor wheel 70 60.5mm
turbine housing A/R .84
T3 flange
$900 brand new in the box, will send interstate if ppl pay postage
call 0401267277
https://www.sau.com.au/forums/topic/71103-brand-new-t70-turbo-bargain/
Couple of questions, Why does it have a label on it calling it a "turbochager" but not a branding? What Brand is it? If its a garrett or a name brand i am very interested but if its a chinese copy i will have to pass.
Cheers
The shaft and wheels are not balanced on the chinese ones, they only work for the shortest amount of time and then thay crap themselves.
XS power, revised not too nice at all check the thraeds below,I did.... scary shit!!
Eye opener,
thanks for the links maximumrpm kinda glad i looked.
maximumrpm to be honest do u know what ur talking about? have a look at the brand the size the specs of the turbos that u have in the link, and where they are made, do they look like a t70 or sound like a t70 to u ? if ur not capable enough to see the masive diference in these 2 turbos i have nothing to say sorry
i will understand what ur trying to do if the turbos where the same or even close
all i can do is laugh at ur links
Is this the Same T70 that "toofast2furious" in sydney sell?
http://www.toofast2furious.com/turbocharges.html
sory guys i seriously dont seem to understand what you all are talking about,
busted? wtf you all make it sound like im selling some stolen item for double the retail price, read the specs on the turbos
and u bust someone if there doing somthing wrong and you find that out, thertes nothing im doing wrong here
you poor bastard - you are just trying to sell a t70 and all you get is flaming.
this is a turbo available from xs-power and ssautochrome in america. it has a 12 months warranty and has been rebuilt with garrett internals - 600hp
the turbo that every1 says blows up from xs-power is the T3 ar50/70 - this is true. but this one is full sick - i have one on my rb20
if you dont want to buy this turbo - dont
leave this poor fella alone - it is genuine. as for the price they are US$470 ish plus US$120 ish postage which is about the $900 AUD mark.
good luck witht the sale - if i decide to go twin T70s on the rb20 i will let you know!!!!
shaunr32
Sorry guys, I should qualify some things. I was interested and was trying to find out who made these turbo's. The buyer was not replying to my requests for info and that combined with other members comments of this brand (no name brand?) made me suspicious. I have done some research and found out the following.
-rebuilt with garrett internals - 600hp- WRONG
-"the turbo that every1 says blows up from xs-power is the T3 ar50/70"- Doesn't give you confidence that the other models in there range will be any different?
But......infairness, It is new, it is unused and I wish him all the best!
Yeah...guys.,.if you have nothing else good to say just let it..ignore it..he's not trying to scum anyone for sure.
T70 has the same spec as the Garrett T60-1,.same internals and is made by MASTERPOWER which used by the same company "GARRETT "..
this one actually capable of handling more than 600HP..pretty much has the same internals as the garrett T60-1.
I know coz i did my search...and YES...I HAVE ONE on my R33.
cost $1200 brand new...$900 is reasonable..but lower it down a bit i'd say..got mine brand new for less.
good luck selling it dude.
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
