Yeah...guys.,.if you have nothing else good to say just let it..ignore it..he's not trying to scum anyone for sure.
T70 has the same spec as the Garrett T60-1,.same internals and is made by MASTERPOWER which used by the same company "GARRETT "..
this one actually capable of handling more than 600HP..pretty much has the same internals as the garrett T60-1.
I know coz i did my search...and YES...I HAVE ONE on my R33.
cost $1200 brand new...$900 is reasonable..but lower it down a bit i'd say..got mine brand new for less.
good luck selling it dude.
thanx for that, ill be taking offers
i Have this turbo on my r33 as well. Makes good power and comes on hard. Had no problems so far. running 22 psi boost all day every day. Bought it new from toofast2furious performance in Maroubra for $1100. This is a pic of my kit before it went on accompanied with stainless manifold and 50mm gate. Turbo currently makes 280kw at the wheels and good for more but my internals are limiting me.
Good luck with the sale
thats looks neat man have u got any pics of it on the car?
Come on.....
Plz note this is a XSPOWER turbo
http://www.mx6.com/forums/showthread.php?t=110947
Yes thank-you for pointing that out again and again and agian,
From what i have read is that you do not wish to buy the turbo so pls stop posting in this tread and let SAU members make there own decisions on the turbo and weather to but it or not.
Im sure you would not like it if other people kept posting negative comments all over your treads.
Rs,
this turbo is not made by masterpower
all master power turbos are branded wit master power in the compressor cover and also the exhaust housing
i know cause ive had 2 of these turbos and several master power turbos and this turbo is nowhere near the quality of a masterpower turbo!!
yes this turbo is from xspower in the states which go under teh name ssautochrome on http://www.ebay.com
heres a link to there store with these turbos
http://stores.ebay.com/WWW-SSAUTOCHROME-CO...sQ3amesstQQtZkm
search thru there n u will find some real cheap stuff but as the saying goes,u get what u pay for
ive bought several gates and turbos from these guys but hav since been resold and 1 gate was stolen
ive now bought there 46mm jdm gate which seems alot beta quality but we will c
it has been posted on forums in america that they (ssautochrome) sell the lower end gear on ebay as thats what sells
just b careful if u buy these turbos, as people hav said, they are using them and they r going great and the dodgy turbo is the t3/t4 that they sell
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
