  • Replies 66
Originally posted by XrSiSt
I'll probably be there at about 7:30 ish... Steak and stay local is
what i'm doing.. i was so tired after the last cruise....
and frank.. u'r the one who was trying to convince me to have
dinner.. so bring u'r a$$ along...
ok ok im going....
g/f is coming along too....
looks like a couples night.....
mark, john
ash, loz
me and my g/f
eric and george ??? pwahahahahahaha now that id like to see...
Originally posted by Zman
BUT WHY!!... i wouldnt mind seeing a dorifting torana!!
Dude i dont need rain to drift lol though i can really only do uncontrolled drift hahahahaha.
Donnie it is grey to me :shake: and i dont really want to risk it ,theres always another monday night dinner thing going to happen oh and if you start to miss me just call me on
1800-ASH-SEX after 10pm oh and make sure your over 18 guys :D
hahahahahahaah
1800-ASH-SEX after 10pm oh and make sure your over 18 guys :)
hahahahahahaah
I keep dialing that number to try to get you but only Frank and Loz keep answering? Why?:D
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
