  • Replies 66
Originally posted by XrSiSt
I'll probably be there at about 7:30 ish... Steak and stay local is
what i'm doing.. i was so tired after the last cruise....
and frank.. u'r the one who was trying to convince me to have
dinner.. so bring u'r a$$ along...
ok ok im going....
g/f is coming along too....
looks like a couples night.....
mark, john
ash, loz
me and my g/f
eric and george ??? pwahahahahahaha now that id like to see...
Originally posted by Zman
BUT WHY!!... i wouldnt mind seeing a dorifting torana!!
Dude i dont need rain to drift lol though i can really only do uncontrolled drift hahahahaha.
Donnie it is grey to me :shake: and i dont really want to risk it ,theres always another monday night dinner thing going to happen oh and if you start to miss me just call me on
1800-ASH-SEX after 10pm oh and make sure your over 18 guys :D
hahahahahahaah
1800-ASH-SEX after 10pm oh and make sure your over 18 guys :)
hahahahahahaah
I keep dialing that number to try to get you but only Frank and Loz keep answering? Why?:D
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
