Hi Guys,
When I'm travelling down the freeway doing 100km/hr , yes I do occasionally stick to the speedlimit, and transfer from 4th to 5th then I get a vibration in the car at any non-idle revs.
I have a twin-pate clutch in the car and the vibration feels similar to when the plates knock together if you have the revs too low and are going to stall. I don't think it is suspension related as in 4th doing the same speed it doesn't occur.
I have a couple possible theories that I would like people to comment on if they have had similar experiences:
1. Could it be the synchros in 5th gear?
2. Could it be the diff?
3. Could it be the clutch?
4. Could it be the lightened flywheel?
I had heard that if you get a lighter flywheel then the harmonic balancer may need upgrading, I have no idea about this so would be grateful for any feedback.
Thanks.
See'ya:burnout:
https://www.sau.com.au/forums/topic/7114-drivetrain-vibration/
I have a vibration from 100 to around 120km's.
It was there with the std flywheel and now its still there with the lightened flywheel.
Maybe the Tail shafts center bearing?
Its only in 5th gear though?!?!
At the same rpm in lower gears the vibration is not there.
I also suspect my gearbox as it has had a input shaft bearing whine since i've owned it.
Possibly causing a little slack?!?!
Who knows.. :D
Thanks for the reply Joel and Fatz. No it doesn't vibrate in any gear other than 5th. I am leaning toward the flywheel as the culprit aswell. What did you do to fix the problem Fatz, have the flywheel balanced or have the harmonic balancer replaced?
Thanks for your help with this guys.
See'ya:burnout:
Hicks,
This is at the same time as I get the forged pistons in, bore the block and shotpeen the conrods. The benfits are that once it is balanced then I can rev harder, and it need to be done with the forged pistons as they weigh less than the factory items.
See'ya:burnout:
Since it only happens in 5th gear, then it seems logical that its something to do with 5th gear.
If it was flywheel or input shaft, etc, then it would likely happen in any gear.
My guess is a bearing on the 5th gear layshaft is on its way out.
Gtst-VSPEC
I have the SAME THING..!!!
Only I KNOW my 4-5th Synchro is rooted! It kicks back pretty badly. It's going in this afternoon to have it fixed, still got 3mth Stauatory warranty.
As mine only does it in 5th Gear, I too assume that it's 5th only... either way they're gonna fix it. I'll let you know how I go with it all.
-Kym.
Strich9ine,
Is your in the transition between 4th->5th or when it is in gear? Mine is when it is in gear, therefore I don't think it is the synchro, I think that it is either the 5th gear or the flywheel. Let us know how you get on anyway.
See'ya:burnout:
Originally posted by GTS-t VSPEC
Strich9ine,
See'ya:burnout:
My transition from 4th-5th kicks back horribly... above 130km/h+ tho..and when changing quickly....
... then all of 5th gear i get that vibration noise....
hence i said before I KNOW my synchro is faulty, as it kicks back when changing... that may be causing the vibration in 5th gear ?
It's in for repair, I'm without a car for a few days :P
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
    • Remember reading about this not too long ago. been for sale for a long time  this is like when the wife says you need to sell the car so you put it up for a ridiculous price no one will pay
    • You are perhaps suggesting that it is not a super car? Well....it's not an AU.
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingie  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like
