im plannin on gettin a set of 256 tomei poncams for rb25det series 2 ( is there much gain from getting the intake side or should i only bother with exhaust side
also i have a hks adjustable cam gear can this work with the poncams or would i need tomei ones?
ben...
https://www.sau.com.au/forums/topic/71157-cams-cam-gear/
My advice would be to sell the adjustable camshaft pulley, you won't need it. The Tomei 256 and 260 Poncams we have installed on RB25's were perfect without changing the exhaust camshaft timing. They are designed to work with the VVT, so loosing it by adding an adjustable inlet camshaft pulley would be a backward step.:)
https://www.sau.com.au/forums/topic/71157-cams-cam-gear/#findComment-1312811
