Originally posted by rob77
I didnt start this thread out to be "my car has more HP than everyone else" i just stated what figure the dynapak dyno read.
*sigh*...
Rob, we are not really saying this either. We would like cars to have more power. Makes it easier to kick Holdes and Fords. :P
But what we are saying is that we find it very strange for an engine of that calibre to pull that amount of horses with the mods that you have done.
(Is it me or is this deja vu with the mid 13 drag times?)
  • Replies 75
Originally posted by IMACUL8
Even a properly tune FMIC is only going to give you max 10 - 12 hp gain on a dyno....
I know this from experience.... as does 25GTT.... and probably a few others.....
A properly tuned FMIC (FMIC + fuel control) should give 30+ hp. I'll confirm that, so will Barrie at Barries Dyno and Steve at SST.
Agreed... BUT i said FMIC only.....
I spotted the possible confusion from a mile away, so I defined "properly tuned" to mean setup in conjunction with fuel control.
I put fuel control in my car went from 181rwhp to 219rwhp.
Nice. Same sort of gain I got.
When i put FMIC later car went from 241rwhp to 252rwhp.
And if you had "properly tuned" the s-afc to suit, there should have been another 20+ hp hiding in there.
Aahh dont for get boost is very relative as the standard intercooler is efficient at 7psi :) the more boost u run the less efficient the ic and more gains to be had when tuned with the bigger ic
You guys should be lucky i got 26hp from turbo upgrade , 2 psi jump and AFC tune! beat that :P
Heya guys,
Well doen Rob at the Horsepower Shootout 2002.
I beleive you took out one of the classes to take yourself home a neat little trophie. Thanks for the mention (Brodie not Brody ;-))
And yeah have a look at the write-up here below
http://home.iprimus.com.au/broffbut/perthhps.htm
Also if you go to the models section you can see the girls, the official All 4 Wheels Promotional Girls, which seems to be the talk of the whole perth car scene!!
cheers guys, well done rob,
Brodie
hey dude, when ya gonna finish the page with all the details on the girls ?
and also, what's the deal, are they gf's of the member's or somethin ??
haha, the models section is coming along...gradually. I got their profiles done up with some nice pics, im just waiting on a couple of things before i upload them. I was plannign having them up when i made that post, but..grr...long story.
and they are all taken.......by me.
Originally posted by DESTROY
Terminal speed is a better indicator for HP...
Only in the same way as a dyno mate (ie: under controlled conditions and with calibration).
Things like weight and diff ratio can have a very large bearing on terminal speed.
    • For me at least the reason why it bothers me is because it's indicative of a deeper problem. And that will nag at me forever. Especially because I have tailpipe emissions testing + evap leak testing every 2 years.
    • WELP. I went to the track, and I suppose it went okay because any time you can drive home is okay. You may notice the car is not on the circuit in this picture. It was about 35C day out in Benalla which means the track was approximately the surface of the sun, probably. Good things, car did not overheat but it _was_ warmer than when I had done track days in similar heat before, I think, I'm not sure - I can't quite remember. Coolant got to ~105 via the ECU after 20-30 minutes of belting it in said heat. Oil got up to 145C in one instance which is pretty crazy due to oil cooler. Pressures were fine. I seem to remember this not getting quite so high before the vents. More HMMMM'ing to be done. On the subject of HMMM'ing, can anyone identify the sounds in the video below, you will know which ones I mean: https://www.youtube.com/watch?v=uj3BkI2cbTc I included some 'normal' sound as a reference for the first minute or so. The microphone in this instance was where the license plate is. It stopped working later in the day which is why my "best example of a lap video (not produced)" had internal audio - Isn't hearable from inside the car. I don't mean the chirping of the un-bedded/badly bedded track brakes which you can only hear while braking... Thoughts, brains trust?
    • blame old mate Hawkins for that one  I remember way back in the day the japanese didn't want them either... they always assumed a race shell would be thrashed. We found a few when looking for an R34 GTR for the Whites to drive in Targa Tas back in 2002.
    • I know it's probably not going to cause any major engine issues. I just had a more generic concern that it's technically not running right (I guess this means the rpm is not sitting where it technically should be) Though the other thing is, it's that my steering wheel is shaking at 1,100 rpm at idle until it gets warm (seemed to happen after I tightened my alternator belt, will be testing the alternator soon).
    • I mean, what's the concern here? Higher fuel consumption? FWIW my idle sits at around 800rpm or so as well. And yes, it runs fine, idles fine and there are no issues as far as I can tell. I don't quite see the problem.
