Thanks Steve,
Even clearer now, just like putting glasses on. I'm running at the Motorplex on Wednesday, I'll fit the pinapples after that and then compare my times.
Anyone with info on running with camber? The R33's do have camber bolts don't they?
See'ya:burnout:
  • Replies 75
Originally posted by GTS-t VSPEC
Skyzerr33,
Thanks for clearing that up, cheers mate.
Rob77,
I didn't say it didn't work for him, but I was told in general that it was a waste of time. Does anyone else run low pressures? If so what pressure and what tyres are they on?
See'ya :burnout:
have drag raced for quite a few years and running low tyre pressures is the way to do things. I forgot to let my tyres down last time and I was lucky enough to meet a bloke with a tyre guage.
19/20 psi or lower for most tyres. Your sidewalls will stay on the rim as long as you don't try going around corners real fast.
Zoom can kiss my ass! A sample size of at least 30 is required to make something statistically valid (though not necessarily absolutley true) I wish I had a dollar for every time something is 'proven' by a test involving 3 or 4 cars, products or runs.
Heyas,
I Have JIC Coilovers and my ride is as hard as all hell! due to the firmness of the coilovers and the hardness will that be an advatnage when i decide to do the quarter? Prob would stop a bit of squatting at the start fo the drag but would it in any way help out wiht wheelspin or would the cradle kit and pineaples still be the way to go?
I guess everyone has their own thoughts on tyre pressure, but personally, I don't think lower pressure on street tyres will make much of a difference.. but of course, there's so many different tyres, and every one runs different rim width and diameter sizes so who knows..... what's good pressure for someone, may prove to be slower for others.
I first run (out of 8) gave me my second quickest time. This was on standard tyre press of 34psi, and I'm pretty sure that my quickest time was only better because I was starting to get the launches down pat. I won't bother lowering pressure next time.
my 2c.
This is just like the burnout, no burnout argument.
I was doin burnouts before each run last wednesday assuming it was giving me traction. Since then i've heard of many people that it makes f#ck all diference on street tyres. But on sunday I started off the day with no burnouts but found first gear just kept spinning. So I tried doin the burnouts again and ran 13.74.
Originally posted by rob77
I couldnt be assed connecting my scanner and loading up the software (cos I havent reloaded it since I re-did windows). So I took a photo of it.
a photo slacker
hey i may be missreading it but when your at the drags that sheet is telling me you should be changing gears just before 5500rpm each change other wise you gonna start decelerating. and you want to be launching at about 2500rpm as you start to get a bag fall of torque then.
Originally posted by skyzerr33
yes i know
but torque is related to acceleration
when your torque starts to drop off is when you want change gears otherwise you'll start to loose momentom. that why i say you have to know your car
Change gears around your horsepower peak buddy.
Before or after depends on how sharp the fall off is and what the gear ratios are like.
Rob: as above.
:P
You also need to take into account where the change will put you in the rev range for the next gear. No use changing at 5500 if it puts you in a crap place in the next gear.
You should experiment according to the dyno sheet and find a balance.
Managed to pull 273.5PS @ 6608rpm on the rear wheels, using Speedworks new DynaPak dyno.
With the mods you have, 273 sounds close to the hp you'd have at the engine, not the wheels. Are Speedworks sure the dyno wasn't set to estimate power at the engine?
in that case I can't help but think you have other mods done to your car than what you're telling us
also why are cars in the wrong classes?? like has everyone had an engine conversion to something drastically larger?
eg ur in 3401cc - 4500cc
what engine u running??
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
